9th February 2008
Posts: 91 Sportster/Buell Model: xlh sportster Sportster/Buell Year: 1978
fuel coming out of vent tube
my '78 has a sudco mikuni carb on it , less than a year old . it has never given me any problems until last sunday. i rode it for about 45 mins & went back home ,shut it off & shut the gas off as i always do , started it back up a few hrs. later & gas pours out the rear vent tube , i shut the bike & gas off it stoped started it back up no gas leaking. started it up today , ran for 1 min. and started leaking gas again , shut off bike & fuel , turn gas back on started it up & no gas leaking . could it be a piece of trash causing this ? thanks for any help regarding this .
9th February 2008
Posts: 23,720 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Originally Posted by t&tkennels
my '78 has a sudco mikuni carb on it , less than a year old . it has never given me any problems until last sunday. i rode it for about 45 mins & went back home ,shut it off & shut the gas off as i always do , started it back up a few hrs. later & gas pours out the rear vent tube ...
I am not familiar with that carb, but if that is an overflow tube, then probably there is a piece of crud getting stuck at the needle valve where fuel flows into the bowl.
A common method to temporarily solve the problem is to shut off the fuel, run the engine until the bowl is empty, then turn on the fuel again. The sudden rush of fuel in often dislodges the crud. This appears to be happening in your case.
Need to dismantle as far as removing the bowl and clear it out. Might also check the fuel tank - clear or rust? - the crud has to originate from that direction.
Some guys [try to] remove the bowl with the carb in the bike. IMO this is a bad idea - best to remove the carb from the bike and work on the bench.
9th February 2008
Posts: 189 Sportster/Buell Model: XL883Slammed Sportster/Buell Year: 1998
What you have is a dirty carb, Do you have an inline fuel filter?, If not clean out your tank,carb, and add a fuel filter in line, After the tank before the carb, The problem you have is the float is sticking causing it to flood over in the bowl, Try this and this will fix the problem you have, very easy fix you can do it your self as long as you have the know how....good luck
9th February 2008
Posts: 987 Sportster/Buell Model: 883 Sportster/Buell Year: 05 Sportster/Buell Model #2: old ironhead . Sportster/Buell Year #2: ??? Other Motorcycle Model: 900 kaw z1 Other Motorcycle Year: 73
YOU always need the small inline filter. As the tanks will let some trash in the gas line if you have one replace it. AND do the shut off and run till it stops as on the above post and turn the gas back on as he said can flush the needle and seat. BUT you will then have it in carb bowl and can get in the main jet and plug that or slow it down (lean it out)So if this helps clean bowl when you can. good luck gar
9th February 2008
Posts: 15,387 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Follow IronMick's instructions and start turning the petcock to the off position every time you shut the bike off. This is a good habit to get in to.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
13th February 2008
Posts: 122 Sportster/Buell Model: 1975 xlh 1000 ironhead Sportster/Buell Year: 75
had the same problem on my 75, did what mick and redneckrider said, flushed it and now it runs fine, mik knows what hes talking about
13th February 2008
Posts: 135 Sportster/Buell Model: Sportster XLH Sportster/Buell Year: 1987
My 87 did the same thing. Turned out I let me tank run low (read empty) the crap dried up and when I refilled it the crap lifted up and passed the petcock filter straight into the carb. I cleaned the carb twice before I realized the source of the crud (Im not the brightest bulb when it comes to maintenance).
| Thread Tools |
| Display Modes |
