The Sportster and Buell Motorcycle Forum Figure Machine
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Sportster Specialty
Biltwell
Old 16th January 2005
jimmyheadgear's Avatar
jimmyheadgear jimmyheadgear is offline
Other Motorcycle Model: Triumph Speed Triple 1050
Other Motorcycle Year: 08
jimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished road
Default HurricaneFlow Air Cleaners
Has anyone tried this setup yet?
http://www.nrhsperformance.com/parts...%20accessories
I don't know anything about carbs or air cleaners so, how hard is it to modify the breather the way they suggest?
Here's the quote from the page.
Note: to maximize power and reduce carbon build-up, these air cleaners do not route the blow-by from the breathers into the intake tract the way the stock air cleaner does. As such, an alternative breather arrangement is needed. There are many different ways to go. We recommend routing the breathers to a small filter (to absorb the moisture component) mounted underneath the bike, or to a catch can. Also, Sportster models will require a carburetor support bracket. For the hardware needed to do these things, please see "General Accessories for Carbs and Air Cleaners" below.
Nightboy's Avatar
Nightboy Nightboy is offline
Nightboy has disabled reputation
I got this AC setup. Bolts up direct to the CV carb, or the the HSR carb with a small adaptor plate and still fits under the stock ham can. Best AC on the market as far as Im concerned. Both K&N filter elements are HUGE! Choose from either a 2" or 3" thick version. I use a Drag Specialties bracket/breather assembly.
Nightboy
Did you modify your breather?
Nightboy's Avatar
Nope, The AC itself doesnt connect at all the the breather. The crankcase breather sits behind the AC out of sight. I used Drag specialties part # DS-289126
Old 17th January 2005
Joshuasws6 Joshuasws6 is offline
Sportster/Buell Model: XL1200 custom
Joshuasws6 has disabled reputation
I also have this setup. I posted several pictures on webshots. I just uploaded them a few minutes ago, so it may take a bit for webshots to upload my album. It is listed in the "Joshuas Harley 2" album.
I took a slightly different approach to the breather. Its not as "clean" as some, but works for me. I mounted a chrome breather the front upper motor mount and ran stainless steel braided line to it. I'm not concerned about oil dripping on the exhaust (if it did, I could always mount the breather on the other side). When I took off my SE setup - after 1300 miles there was NO oil accumulation in the carb neck, nor in the littler rubber breathers that I could see. I have ridden the bike relatively aggressively for the last 1000 miles so dont expect to see any appreciable oil blow by.
The album should be available shortly. The order of the pics/install is "Harley 1" through "Harley 13". If you cannot upload / enlarge the pictures, then try again a bit later.
http://community.webshots.com/user/joshuasws6
Direct link to the album (may or may not work):
http://community.webshots.com/album/252608383VJgpSS
Joshuasws6
Nice bike! Is that the 2" filter?
Thanks for the compliment!
Yes - its the 2". It only sticks out maybe another 1/4" to 1/2" compared to the S.E. I dont even notice it when riding and I'm pretty short (5'8").
dabronco's Avatar
dabronco dabronco is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH (ironhead)
Sportster/Buell Year: '77
Other Motorcycle Model: Sold it!!
dabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura about
How does it perform?
Murphy is my co-pilot.
Turbota's Avatar
Turbota Turbota is offline
Turbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really nice
Josh ...
I really like your formula ... Here is a couple of links to my old TA:
http://img.photobucket.com/albums/v2...ota/TALeft.jpg
http://img.photobucket.com/albums/v2...ota/TARear.jpg
http://img.photobucket.com/albums/v2.../TAEngine1.jpg
http://img.photobucket.com/albums/v2.../TAEngine3.jpg
mikeLI_77's Avatar
mikeLI_77 mikeLI_77 is online now
mikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to allmikeLI_77 is a name known to all
that's pretty cool. that braided line makes it look good. big difference over the rubber line
2002 XL1200C (originally)
Stage II Buel XB Heads, Andrews N4 Cams, Mikuni HSR42 Carb, Forcewinder Air Filter with Float bowl vent mod, S&S Roller Rockers, Jim's Powerglide Lifters, Thunderheader Exhaust, Daytona Twin Tech SIngle Fire Ignition, Crankvents.
Max Power=85.47
Max Torque=81.84
Flow Bench Results
Similar Threads
HurricaneFlow Air Cleaners aswracing NRHS - High Performance 85 10th September 2005 18:25
HurricaneFlow 3" for 2004 gilx Product Reviews 5 29th May 2005 05:06
3" HurricaneFlow AC installed bplinson NRHS - High Performance 2 23rd April 2005 16:13
HurricaneFlow Air Cleaner Came Today raysheen Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 8 14th March 2005 00:25
Spacing on Breather Holes-NHRS HurricaneFlow Breather shooter Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 13 8th February 2005 00:22
