The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Sportster Motorcycle Project
NRHS Performance Long 2
Biltwell
Old 2nd December 2005
Texas Roadster's Avatar
Texas Roadster Texas Roadster is offline
Texas Roadster has disabled reputation
Default Toasted my Turbo
well, not toasted, it seems as if the turbo has some shaft play in it, I tore the critter down for inspection due to the oil consumption I mentioned last night and blammo, I find shaft play. So's I went around the local supply guys and called central motive power, North American garrett distributors. I feel pretty certain I didnt get the right turbo, or basically it didnt have the carbon thrust washer needed for gasoline use as was told . I called, they confirmed, lesson learned, do things yourself. I am working with Patrick at CMP and am either going to get this one redone with the correct seal if possible since I am way happy with its performance and would rather re-use, and I'm set up with garrett flanges etc.
Or am going to go with what Sam has used for years, a warner-ishi rhb-52. The WI stuff is a bit harder to get stuff for, and a bit pricier, and a slightly larger turbo (spool time added), but it is known to work flawlessly with the draw through design. I'll have more info on Monday I'm sure , right now, I'm not gonna run this turbo like it is.
Sam, on the 883, how is the response? boost at what rpm?
God loves you
Turbo and heavily Nallinized XL1250R
UPDATES at: MuddyJEEP.com/turbo_update.htm
Old 3rd December 2005
Dakin Engineering Dakin Engineering is offline
Senior Master Bike Builder
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Response is good on a 883, better on a 1200, OMG on 88". It makes boost as soon as you get the throttle slide out of the way. I don't have a tach or pressure guage on the 883, but I can sure feel my arms getting longer....
Sorry to hear of your problem,
Sam
rottenralph's Avatar
rottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant future
Lets see a pic and some info on cost. A turbo is a nice option for the right price.
Sam
HAHAHAHA, knuckles draggin the ground after a sunday ride
Mine will be back on the road soon enough, not to worry
Ballpark kit cost of 2,500. It really depends on the next couple of days and what turbo we end up with and the cost of said turbo's at a group buy price.
I am working with a company to supply either of the two that ends up the choice turbo at a group buy rate.
Not only get the performance of a turbo , but crap, how many do you see at the local bike meets with a turbo hangin off the side. Its kinda like walking around muscle beach and your the one flexin'
Turbota's Avatar
Turbota Turbota is offline
Turbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really nice
Texas Roadster ... Have you considered Precision Turbo and Engine (PTE) for a Garrett?
http://www.precisionturbo.net/
actually, the first place I called was Central Motive Power, garrett and warner distributers.
I will cetainly make a call and bend the ear of their tech also to see what they think on Monday and then make a decision and place an order from somebody for something on Monday to get it here before the weekend.
thanks indeed.
Old 5th December 2005
hondo hondo is offline
Other Motorcycle Model: ZX12R Kawasaki
Other Motorcycle Year: 2000
hondo is an unknown quantity at this point
I think we're going to need to re-define the stages of Sporty modifications since a turbo can be used with any of the stages. I think my stage 1 1/2 will now become a stage 1 1/2*.
Turbota's Avatar
Properly lubricated, a new Turbo should certainly last longer than the one you used. I sure hope it had something to do with that carbon seal.
I personally know of many people with 80,000 mile tubos pumping over 18 lbs boost at the track every other weekend.
STEVOMERCKX's Avatar
STEVOMERCKX STEVOMERCKX is offline
Sportster/Buell Model: Sportster XL883
STEVOMERCKX is on a distinguished roadSTEVOMERCKX is on a distinguished road
i had 123,000 miles when my turbo took a crap on my talon. it ran anywhere from 15-18psi. my evo ran 22psi woot woot, and my friends eclipse ran over 30psi
