22nd March 2008
Posts: 2,619 Sportster/Buell Model: 1200 XLH Sportster/Buell Year: 2002
Will these pipes fit?
I have opportunity for some screaming eagle exhaust off a 96 Sporty. They have a cross over at the bottom of the pipes just before the mufflers. I believe that typically exhaust systems are interchangeable between 88 through 2003. Just wondering if anyone has thoughts on this? Is this typical of exhaust pipes that do not have the "high" crossover to have something lower?
I have a 2002 XLH. I'm looking for some pipes to eliminate the crossover tube that is near the cylinders. These have a crossover down low before the muffler, which I want to change out to the HD larger slant or bologna cut mufflers. Anybody familiar with this?
Denny
22nd March 2008
Posts: 2,631 Sportster/Buell Model: 94 HP XL1200C sold :( Sportster/Buell Year: 2002 Sportster/Buell Model #2: Yamaha Raider Sportster/Buell Year #2: 2010 Other Motorcycle Model: Yamaha FZ1 Other Motorcycle Year: 2008
I looked in my 02 parts book and the only issue I see are the mufflers. They are -00 which means something changed in 2000.
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
22nd March 2008
which is ok as I plan to use different mufflers. These "new" pipes have the stock looking mufflers. I did not have a chance to see if they are open or straight thru.
My two concerns are the head pipe fitment and the crossover and whether it would fit or interfere.
22nd March 2008
Posts: 9,966 Sportster/Buell Model: 1998 S= Superior Model Sportster/Buell Year: 1998
we have a 97 and A 2001 here and they are the same so they will work !
Sportsters Rule !
22nd March 2008
Thanks! These have less than 1500 miles and the guy did not like them and took them off. May offer $100 for them and go from there.
23rd March 2008
kdarejr.... question.... there is a small crossover pipe down low on the pipes, before the mufflers. Do you think this interfere on anything? I'm not sure if this crossover is unique to earlier models or this style pipe, or if it is unique to screaming eagle pipes?
23rd March 2008
do you have a picture or a link to what the pipes look like ??
23rd March 2008
Posts: 810 Sportster/Buell Model: XLH 883/1250 Sportster/Buell Year: 2003
I thought the low crossover was a product of 04+
03 Vivid Black 883/1250, with 04 1200r/XB heads, Andrews N4 cams, Hurricane push rods.040 shorter than stock. Dyna 2000i ignition, Screaming Eagle ignition coil and wires. V&H Straight Shots, Generic tear drop with 3in wide K&N filter, 48 slow, 175 main, NOKH needle shimmed .043. Progressive front springs, 412 rear shocks. ♠ 79.5 HP, 77.96 TQ ♠ ~Kevin~
23rd March 2008
Posts: 1,277 Sportster/Buell Model: XL883 (traded) Sportster/Buell Year: 2007 Other Motorcycle Model: FXDC Super Glide Other Motorcycle Year: 2009
It is. There is no crossover port on pre-04 Sportster mufflers.
The mufflers this guy is trying to sell are either not Sportster mufflers, or they are for 04 and up models.
23rd March 2008
It is the complete exhaust, with heat shields. I was told they are screaming eagle, and the mufflers are the tapered stock looking mufflers. I will have to make arrangements to get back out there and take some pictures. If I remember, it seems the crossover tube was just in front of the mufflers and went from the front pipe back to the rear pipe. I also seemed to have a black shield covering the tube.
Looks like a quick trip next week with a camera.
| Thread Tools |
| Display Modes |
