The Sportster and Buell Motorcycle Forum Figure Machine
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
NHRS Performance
Marks Moto Gear
Figure Machine
Licks Cycles
Old 25th March 2008
Vicente José's Avatar
Vicente José Vicente José is offline
Vicente José is an unknown quantity at this point
Default Stock XL1200R '05 shocks size.
Hi all!!
Which is the size of a XL1200R stock shocks????
Thanks.
Vicente José.
XL 1200 R '05
Stock air box without restriction with K&N filter element.
SEII slips on with drilled holes.
Stock needle, 45 pilot jet, 180 main jet, drilled vacuum port.
Old 25th March 2008
Length?
I think 13.25"
but try a search to be sure (cause it's been discussed about 100 times )
Old 25th March 2008
Originally Posted by Kev M View Post
Length?
I think 13.25"
Yes, length...
This seemed to me. I want change to Progressive shocks, but they jump from 13" to 13,5".
Thanks.
Old 25th March 2008
Originally Posted by Vicente José View Post
Yes, length...
Thanks.
1/4" difference is not much for a shock. You can probably go with either length.
If it were me, I'd go with the 13.5" because I want as much travel and ground clearance as I can get.
Kev
Old 25th March 2008
Bob F's Avatar
Bob F Bob F is offline
I'm running the Progressive 13½" shocks and love them. My 2¢.
