Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Drivetrain > Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive
Progressive Suspension
Ricor Shocks
NRHS
NRHS Performance Long 2
Zippers Performance
Old 28th March 2008
PBR's Avatar
PBR PBR is offline
Sportster/Buell Model: 883xl
PBR is an unknown quantity at this point
Default trouble with derby cover
having trouble getting one of the screws out of my derby cover, it just wont budge. any ideas on the best tool for the job? thanks!
Old 28th March 2008
jcastino jcastino is offline
jcastino is on a distinguished roadjcastino is on a distinguished road
Take a hammer and smack the end of the torx head. That should help seat it onto the head. If it does not work, smack it again.
Old 28th March 2008
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
Make sure you're using the correct size of Torx bit, which is a T27. A T25 will fit in the screw, but is likely to strip it out.
Folkie
'The green machine'
Old 28th March 2008
XLXR's Avatar
XLXR XLXR is offline
XLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to behold
I don't know if they still make them, but I used to have a hand held impact driver which you smack with a hammer. Worked good with phillips screws, don't know if it will works with Torx. Maybe a screw extractor will be needed. I see TV advertistments for a set that comes with a drill and an easy out matched set.
Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
Old 28th March 2008
jimmyheadgear's Avatar
jimmyheadgear jimmyheadgear is offline
Other Motorcycle Model: Triumph Speed Triple 1050
Other Motorcycle Year: 08
jimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished road
They still make them. If you have a decent torx bit it should work good. Mine does.
[COLOR=Sienna][SIZE=3][FONT=Arial Black][COLOR=Black]Pete
[/COLOR][/FONT][/SIZE][COLOR=Black][FONT=Arial][SIZE=2][IMG]http://i19.photobucket.com/albums/b189/jimmyheadgear/croppedDSC_2160.jpg[/IMG][SIZE=4][B]
It's a shame that stupidity isn't painful!
[/B][/SIZE]
[/SIZE][/FONT] [/COLOR][/COLOR]
Old 28th March 2008
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant futureSpartanDen has a brilliant future
Just went through this last fall. Two of the four screws would not come out. Use an impact driver. If that does not work, try a small propane torch. I heated up the areas around the screws (on the case, not so much the cover or screw) then used the impact driver. It took about 20 minutes per screw to heat up and remove. I went in stages, trying to apply heat, let it soak, apply heat, soak, then try the impact. I was trying to minimize excessive heat and burn or tarnish the alum.
It took awhile, but we finally got them out. Just a dab (a small dab) of loctite this time!!
Denny
Old 28th March 2008
Dlish's Avatar
Dlish Dlish is offline
Sportster/Buell Model: motorcycle
Other Motorcycle Model: Bastard mess of parts
Other Motorcycle Year: 1941
Dlish has disabled reputation
As above, hit the end to get it to seat all the way, I still managed to strip one and used a reverse drill bit thing to get it out. I replaced all the torx with allen cuz i like them more
"Well why don't you cry about it, saddlebags!"
Old 28th March 2008
liceboy liceboy is offline
Sportster/Buell Model: xlh883
liceboy is an unknown quantity at this point
Yeah, when you do get them all out, replace with stainless or chrome Allen (hex) screws. I hate Torx heads, they always feel like the driver is about to twist round and wreck the head.
I don't use any thread lock on mine, just a bit of copper grease to (hopefully!) stop 'em seizing. They've never worked loose yet.
Old 28th March 2008
klinesamuel klinesamuel is offline
Other Motorcycle Model: FXB Sturgis
Other Motorcycle Year: 1980
klinesamuel is on a distinguished roadklinesamuel is on a distinguished road
Last year I had this problem with five of the derby screws. I ended up just cutting a slot in each screw head with my Dremel tool and a cut off wheel. After the slot was made I simply used a slotted screwdriver and took them out. They were stripped anyway so cutting the slot really didn't make them any worse then they were already.
Sam
Old 28th March 2008
gearhead1972's Avatar
gearhead1972 gearhead1972 is offline
Sportster/Buell Model: XLH 883/1250
gearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura about
home depot and lowes have locktight
03 Vivid Black 883/1250, with 04 1200r/XB heads, Andrews N4 cams, Hurricane push rods.040 shorter than stock. Dyna 2000i ignition, Screaming Eagle ignition coil and wires. V&H Straight Shots, Generic tear drop with 3in wide K&N filter, 48 slow, 175 main, NOKH needle shimmed .043. Progressive front springs, 412 rear shocks. ♠ 79.5 HP, 77.96 TQ ♠ ~Kevin~
