The Sportster and Buell Motorcycle Forum CV Performance
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Ricor Shocks
Primordial Cycles
Get Lowered
Old 4th April 2008
rottenralph's Avatar
rottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant future
Default Where is the case drain plug
I need to drain the oil from the cases and I can't get my head under the bike enough to see where the case plug is. Please be specific about the location cause I can't find the fricken drain.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
Old 4th April 2008
Mr Jimi's Avatar
Mr Jimi Mr Jimi is offline
Riding with Angels
Sportster/Buell Model: XL 1200 C Black & Silver
Mr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of light
Is this the plug your looking for here
my weather
home depot
A very touching video here
Making a F-550 Pick Up Thread
We are not near but we are close !
Amanda Overmyer Rocks !!
Dear Eliot
Eye Xray Here
Old 4th April 2008
No, that is the primary drain plug. I need the case drain, I know it has one but it is not easy to find. The garage is a little cramped right now and I am not digging on laying in the mess my bike has created.
Old 4th April 2008
Someone must know.
Old 4th April 2008
Mr Jimi's Avatar
Riding with Angels
If you have a mirror in your garage that will do the trick or just pass your hand under there, I think if there was one, the guy in the oil thread would have drained it? And you should be able to see from the right side if your bike is on stand
Old 4th April 2008
Joe Dirt's Avatar
Joe Dirt Joe Dirt is offline
Joe Dirt has disabled reputation
On my '03 there is a little allen head plug directly in front of the rear frame cross brace (where the sidestand is located), to the right side.
Old 4th April 2008
I saw a little 3/8's hole in the bottom but I could not see the allen. I think I know where it is. Thanks dirt. I will stick an allen in there and see if it is there.
Old 21st April 2008
fixerdj's Avatar
fixerdj fixerdj is offline
Sportster/Buell Model: 883/1200 deluxe
Other Motorcycle Model: kaw kz1100
Other Motorcycle Year: 1983
fixerdj is an unknown quantity at this point
Why would you need to drain the case? It's a dry sump engine. If you run it a short time the oil should return to the oil tank. On my '92 the tank drain is a rubber hose clamped the a frame stub under the battery.
Jihad this! (see avatar )
Old 21st April 2008
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
I drained the oil prior to engine dissassembly, but as parts came of it was obvous there was still a couple cups of oil in the motor.
2002 157 hp sportster nearly in the nines...
1995 Blacked out Cafe style 1200 with xb conversion.
The cannons don't thunder ,there is nothing to plunder.
My Caribbean yearnings 200 years late. I am a forty year old victim of fate. Arriving on the scene 2 centuries late. Alas I am glad still, for having found me best mate. With the wind in my sails...n the rubber side down, I cruise dangerous land ,they all know me in town. No parrot, no sword..with regular life I be bored. So I does what I can, We don't set ships a sail,we aint walked no planks, but we live best we can and for that we give thanks.
Old 21st April 2008
Urrell's Avatar
Urrell Urrell is offline
Other Motorcycle Model: Electra Glide Ultra Class
Other Motorcycle Year: 2009
Urrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of light
The oil tank drain is in the pic supplied by Mr Jimi.
It's the rubber hose and you can see in the picture its draining.
