20th January 2006
Help Installing New Grips
I have ordered some new grips, and I am looking fo some tips on installing them. The instructions that came with the grips says that I need the service manual - which I don't have at this time. I am wondering if I need to disconnect cables etc. Also looking for some lubricating tips so the grips go on smoothly.
Any help is appreciated.
Thanks, Bob
20th January 2006
Posts: 527 Sportster/Buell Model: XL1200C (Heywood) Sportster/Buell Year: '05 Other Motorcycle Model: Ultra (T-Bagger) Other Motorcycle Year: '03
There needs to be a cardboard shim installed between the lever and the front brake switch or the switch can be damaged. (I used a peice of a matchbook) Not to be a smart ass, but having the service manual makes thangs go a lot smoother. Lot less chance of ficking something up. Also when removing the switch housings, make sure you are using the correct size torx driver. (The heads seem to strip-out easily.) Soapy water makes for a good lubricant and cables will have to be switched between old and new grips. (No big deal, just pay attention).
20th January 2006
Thanks - I think I will get the repair manual.
Bob
20th January 2006
Posts: 353 Sportster/Buell Model: 1200 Custom Sportster/Buell Year: 2004
Look under "Accessories" for a thread on installing grips that I had started. Gary put in there a GREAT diagram etc. I put them on myself with no problems. You shouldn't need any lubricant to put the new ones on, I didn't. I put the HD flame grips on and I really like them. It was pretty easy. Just make sure you keep a hold of the brass ferrels? (thingamigis) They have a tendency to take to the air. Good luck!
20th January 2006
Posts: 5,768 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2007
I remember that thread and Cyn is right, pretty much all you need to know. Look it up with the search function.
And definately get the manual, little things like that piece of cardboard are often overlooked and result in damaged in switches and bigger headaches.
Oh and a note on the torx heads, there are two different sizes on the housings. 26 and 28 if I remember right.
21st January 2006
Posts: 504 Sportster/Buell Model: 1200R Sportster/Buell Year: 2005
Not sure how applicable this is to Harleys, but here's some hints from when I switched grips on a Moto Guzzi I used to own. Use some compressed air, and use a screwdriver to open up some space between the grip and handlebar, and blow some air in there. The grip should come right up, and come off pretty easily. For installing the new grips, what I did was spray some hairspray on the inside of the grips, and that made the grips go on nice and easy. Plus, when the hairspray dries, it gets pretty sticky and keeps them in place (especially the left one).
Good luck...
Robert
'05 Sportster 1200R: HD headlight fairing and chin scoop; Wilwood 4-piston calipers; HD Thunderstar wheels, full-floating rotors, s/s brake lines; lots of black parts incl RB Racing LSR 2-1 exhaust; fork boots, handlebars, mirrors, misc hardware; black HD air shocks; black HD oil cooler; RamFlo 400 a/c; custom black paint with chameleon flames; etc.
21st January 2006
hope you don't have the same situation i did. my cables were just a tad short, so i had to take the handlebars off to change my grips out. the cables are not too short when everything is together, just too short to reach out past the end of the grip. if you don't understand what i mean, you will when you get to that part. just take it nice and easy and pay attention to how things are lined up and you won't have any problems.
21st January 2006
Why would you need the cables to reach out past the grip? You must have seated the ferrules into the grip and then tried to install the grip right?
If you put the grip in place and then seat the ferrules (cables) that shouldn't be an issue. Granted getting the ferrules into place can be a PITA.
21st January 2006
Posts: 1,623 Sportster/Buell Model: XL883C (1235 Conv) Sportster/Buell Year: 2005 Sportster/Buell Model #2: XL883R Sportster/Buell Year #2: 2006
With the factory service manual I changed out my grips myself. If you run into any problems and need a specific suggestion I might be able to help. But definately get the service manual and give it a whirl. Also good is the parts manual which has some great diagrams. Once you see a picture of how everything fits in there it all comes together.
And make sure you wedge that piece of cardboard in there.... I forgot to do that and now I need to replace the switch. Waiting until I put my wide glide bars on and will replace it then.
Erica in KC (Red)
[IMG]http://www.mytriplogs.com/sigs/mtl_create_us_states_map.php?rz=75&vu=uvuvvvuuuuuuvvvvvuuuuuuvuvvvvuuuuuvvvvuuuvuvvuuvuvv[/IMG]
[B]"Ruth"[/B] '05 XL883C -> 1212 -> 1235 (don't ask) - Pearl Yellow
Progressive Fork Springs, Progressive 412s w/ heavy duty springs, 883 -> 1200 NRHS conversion (at 1235 Now), Daytona Twin Tec Ignition, Hurricane AC
21st January 2006
Posts: 121 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2004
Read the manual!
The throttle cable adjustments to the carb need to be loosened to facilitate the cable removal and installation. If you don't loosen the adjustments, I guess you remove the bars to change!
2004 XL1200C, Mag front with Avon Venom X. 160 Metzler on back. Stage 1 w/ round air filter, detachable sides with sissy. Ghost Brackets w/ leather covered hard bags. Relocated rear turns w/ HD brakelight module, Mini-apes, ISO grips with rocker, trim on front fender, batt cover, oil tank cover, temp dip stick. 05 headlight w/modulator on high, Kuri silver bullets front. Polished SuperBrace, AMSOIL.
Wizard
Mavericks MC
MFFM
| Thread Tools |
| Display Modes |
