28th April 2008
Posts: 103 Sportster/Buell Model: sportster 883/1200 Sportster/Buell Year: 99
6 inch risers... Anyone use them do they work with stock top clamp?
Description says it will work with stock top clamp but im curious to see if anyone has used these? I would like to raise my bars some without changing much.
Would my stock cables be long enough.. Any help would be great thanks!
99 Custom 883/1200 conversion, Longshot pipes, Solo seat, Forward controls, Screaming eagle breather, Screaming eagle street legal igntition module, Screaming eagle plugs, Stage 1 carb kit, Exhaust POWER TORQUE CONES.
28th April 2008
Posts: 15,386 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Top clamp is not a problem. Cables will probably need to be changed. It really depends in the type of risers and your model of bike. Maybe someone on here has your model with the six inch risers and can give you a definite answer.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
28th April 2008
Ride That F'N Sportster!!
Posts: 12,067 Sportster/Buell Model: Highly modified 1200 c Sportster/Buell Year: 01 Other Motorcycle Model: FLHX H-D Street glide Other Motorcycle Year: 2013
Using the stock C clamp will only work with the stock C riser, if your asking if you can use aftermarket or H-D 6" risers with stock clamp??
then NO it won't........... Only way would be to use a stock BT top clamp on 6" risers not the stock C clamp!!
RTFS Ride That F'N Sportster!!
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
29th April 2008
Posts: 209 Sportster/Buell Model: 883 low Sportster/Buell Year: 07
i have to disagree with ex the top clap should work with a six riser, i had six inch risers on mine with drag bars on it and had no problems i now have mini apes with stock cables.
29th April 2008
So ur stock cables were long enough?
29th April 2008
Red Beard Cycles
Posts: 9,798 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997 Other Motorcycle Year: ALL
You have a LOW, which is different then the custom.
The CUSTOM Stock clamp is different.
But where are you going to put all your wires ??? They are inside the Custom's Riser Housing....
The pic below is using 5 1/2 in PULLBACK risers with a replacement clamp. No adjustments were made to the cables (As there is plenty of extra coming from the stock bars to the drag bars) You may not have the same luck. There are plenty of the normal stock ones available for very cheap..
or you can spend about 10 bucks and get a chrome one.
I AM THE REAL BAT-MAN!
You Can't Fix STUPID !
Originator of the " NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
29th April 2008
Ok changed my mind i def want these bars in stock clamp. So everything should be kosher if the wires are long enough...?
http://cgi.ebay.com/ebaymotors/CHROM...QQcmdZViewItem
29th April 2008
Red Beard Cycles
Originally Posted by bL33d
YUP everything should be AOK as long as the wires are long enough. !
Nice bars BTW
29th April 2008
i think front brake line will be my only problem.
29th April 2008
you may have to bend it a little bit to get it to work but i pretty sure you will be fine cuz like i said i have apes on mine with stock cables
| Thread Tools |
| Display Modes |
