Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Biltwell
Progressive Suspension
Get Lowered
Licks Cycles
Old 24th November 2007
Maxanimal Maxanimal is offline
Sportster/Buell Model: 883 not so Low
Maxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the roughMaxanimal is a jewel in the rough
Originally Posted by dave76 View Post
Also remember Harleys engine is basically an airplane Radial engine with just two cylinders. Just check out some old photos of WW2 B17s and the Navys Hellcats. Thay were all radial engines, with cylinders spacing 45° appart.
I doubt a ten cylinder radial engine would be spaced 45 degrees.
havi0412c's Avatar
havi0412c havi0412c is offline
Sportster/Buell Model: Xl1200C
Other Motorcycle Model: Speed Triple
Other Motorcycle Year: 1995
havi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nicehavi0412c is just really nice
some cool reading, speaking of radial engines and such. it also has an animation of a 5 cylinder radial engine. The radial spacing of the cylinders seems to depend on how many cylinders there were. this article states that 4 stroke engines usually have odd numbers of cylinders to run smoothly, hence the talk of 7,9 and 5 cylinder engines. cool article.
http://en.wikipedia.org/wiki/Radial_engine
Drag Strip King of the Gas Guzzlers MC
Don Burton's Avatar
Sportster/Buell Model: XL 1200 R SOLD!
Don Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud ofDon Burton has much to be proud of
You're correct. A ten cylinder radial engine would have 36 degree spacing between cylinders.
Don Burton's Avatar
Originally Posted by xl1200r View Post
Techi person, here I go...
The pistons move sort of together, they are actually 45* apart on a common crank pin. What was said is true, they alternate which piston is firing. So while on piston fires and forces both down, the other has the intake valve open and is drawing in fuel (4 strokes...Down(intake), up(compression), down(ignition), up(exhaust).
What makes the "patato patato" sound is that the engine is "odd-fire", in that the spacing between the firing is not equal. You get cylinder 1 to fire, the crank turns 315*, then cylinder 2 fires, but the crank has to turn another 405* for cylinder 1 to fire again. This is due to the 45* piston angle and the common crank pin. This means that there's almost a 30% difference in the amount of time it take for each cylinder to fire from the other cylinder firing.
I wish I could find this animation of the whole thing happening - it's be much easier to understand when you see it.
Try this:
Hope that helps.
You've given a good explanation which I'd like to elaborate on. The cylinders are odd fire as you have explained. The pistons neither go up or down together nor do they oppose each other. The odd fire is due to the two connecting rods riding on one journal with the cylinders spaced 45 degrees apart as you have said.
Also, some have thought that the simple 45 degree arrangement gives more power. Well, thats almost the opposite of correct if you're talking about peak HP at high rpm. This is an inherently unbalanced motor and that lack of balance along with the long stroke ensures that it could not live as a high rpm, high peak output motor. With that fact in mind, H-Ds have always had fairly broad powerbands due to the valve timing of the camshaft along with combustion chamber design. A 13,000 rpm machine can't make any power at 3,500 rpm where our carbed 1200 Sportys put out max torque. H-Ds can be designed to make power down low as they don't have to (and can't) make power at 13,000 rpm. Put "bigger" cams in the Sporty and it will lose some of that power band and raise it at the peak which is still relatively slow at around 7,000 rpm. Low speed torque (twisting force) is what makes these things fun to ride.
oakies's Avatar
oakies oakies is offline
Sportster/Buell Model: Dyna Wide Glide
Sportster/Buell Model #2: Roadster
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Ultra Classic
Other Motorcycle Year: 2011
oakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura about
Nobody but Harley would use such an outdated, inefficient design in a modern engine..Hence the potato-potato sound...That we love
04 Roadster
06 Dyna Wide Glide
Everyone know that Silver is the fastest
[url=http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=1778][B][SIZE="2"][COLOR="Red"]View My Gallery[/COLOR][/SIZE][/B][/URL]
[IMG]http://i21.photobucket.com/albums/b294/oakie10us/bothbikesnewcopy.jpg[/IMG]
dave76's Avatar
dave76 dave76 is offline
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nicedave76 is just really nice
Yeah you guys are right I forgot about all the multiple cylinder arrangments. I do know the B17s were a Curtis Wright Cyclone 9 cylinder not sure of the cylinder spacing. I think the B24s and B25s had 14 cylinder engines. The B29 was the crazy one with 28 cylinders. Question is how weird was the timming on those engines?
1990 1200 Sportster, Cycle Shack drag pipes, V-Twin billet 3" extended forward controls, Khrome Werks 12" Narrow Glide Apes, Zippers Billet 4 speed trap door.
Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition.
Old 25th November 2007
Don Burton's Avatar
A nine cylinder radial engine would have 40 degrees between each cylinder. It's simple. Just divide 360 degrees by the number of cylinders unless there's another set of cylinders behind the first set.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
Originally Posted by oakies View Post
Nobody but Harley would use such an outdated. inefficient design in a modern engine.
I know; great, isn't it?
Folkie
'The green machine'
Old 8th February 2008
wilbur's Avatar
wilbur wilbur is offline
The crazy one...
Sportster/Buell Model: rigid 88" highly modified
Sportster/Buell Year: '03
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Can you picture this in an XL frame?
It is now "later" than it has ever been!
Old 9th February 2008
SPURS-DarkRider's Avatar
SPURS-DarkRider SPURS-DarkRider is offline
Sportster/Buell Model: 1200XLC
SPURS-DarkRider is an unknown quantity at this point
great animation and explanation, i learned something new today.
