Biltwell
Dead Creek Cycles
Ironworks Magazine
Old 10th May 2008
motomotard's Avatar
motomotard motomotard is offline
Sportster/Buell Year: 72'
motomotard is on a distinguished roadmotomotard is on a distinguished roadmotomotard is on a distinguished road
Default 72' ironhead. how do i remove the swingarm?
i dont have a manual yet so im in the dark. i dont want to do anything stupid so i thought id ask.
i removed the bolt that runs through the center, but the swingarm wont come off. do I need to do something else, or just big boy it off?
thanks
Old 10th May 2008
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: XLH 62, 65, 68, FLH 1970
Moon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to allMoon Wolf is a name known to all
If the center bolt is out, the swingarm should come off. It's a pretty tight fit to the frame, but you should be able to tap it off.
Old 10th May 2008
motomotard's Avatar
ive been bangin on it with a rubber hammer, and it dosent want to move.
Old 10th May 2008
Reverend G's Avatar
Reverend G Reverend G is offline
Sportster/Buell Model: roadster XLS
Reverend G is on a distinguished roadReverend G is on a distinguished road
Default This always works!!
SAWZALL!!
Then you have your rigid project all set.
Old 10th May 2008
stealthammer stealthammer is offline
Riding with Angels
Other Motorcycle Model: Yamaha XT550 mutant
Other Motorcycle Year: 1982
stealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nicestealthammer is just really nice
Originally Posted by Reverend G View Post
SAWZALL!!
I'd use angle grinder cause I like the sparks......
-Barry
Stealthammer
1975 XLCH Ironhead - Stage II/1200, and oh yeah... It's Black!
"No matter how much you learn about computers, someone will always ask you to fix their car."
Still missin' Mr. Jimi......
XLF member's son needs our help!
Please Support Red Friday!
Old 10th May 2008
Moon Wolf's Avatar
Bigger hammer.
Old 10th May 2008
Hopper's Avatar
Hopper Hopper is online now
Other Motorcycle Year: 1942
Hopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to all
WD40.
Get a jimmy bar up between the cross piece on the swingarm and the frame. Use abit of wood so the bar does not scar the frame.
Make sure the nut on the left hand side is not jammed in the slot in the back of the primary cover. With the back shocks off, jiggle swingarm up and down to free up that nut. The nut has kind of a raised piece about 3/8 wide that engages in the slot in the primary cover.
Old 10th May 2008
Moon Wolf's Avatar
WD40.
Good point. You need to pull the swing arm straight back if the motor is still in the frame.
Old 13th May 2008
motomotard's Avatar
this bitch wont come off. i still cant get it out. what about the large 1 1/4" ish nut on the right?
Old 13th May 2008
fdny37's Avatar
fdny37 fdny37 is offline
Senior Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Model: Softail Deluxe
Other Motorcycle Year: 2007
fdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nice
That nut just set's the load on the bearing. If the engine is still on the frame you will have to pry it off. Try some WD40 and let it soak for awhile and then maybe heat the frame with a heat gun and try to get a pinch bar in there to get it started. It's like a babe and just being difficult.
