Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
NRHS
Old 19th February 2006
LordVngr's Avatar
LordVngr LordVngr is offline
Sportster/Buell Model: XL1200RS Phantom
Other Motorcycle Model: Kawaski KLX250S
LordVngr is on a distinguished roadLordVngr is on a distinguished roadLordVngr is on a distinguished road
Default Starter Problems Or is it Just Me
I wanted to discuss a situation I Think I have but dont know for sure. I saw another post like this awhile ago but didnt see to many replies to it so I wanted to broch the subject again. In short I wonder if I have a Starter Issue with my 05 1200R.
You see my bike starts cold fine Every Time and starts fine about 80-90% of the time after it's been warmed up too. But every once in a while I will go to hit the starter switch and it will seem to Hang. Kind of like its on the compression stroke and cant follow thru. Or once in a while it will actually Clang like the starter bendix and ring gear are Not Meshing and Hitting each other.
Once I let go of the starter button and press it again the bike will start fine at that point. Or if I hit the switch for just a sec to Clear it and then try to start it then it starts fine too. I Start the bike with the neutral light On and the clutch lever pulled in. Part of me has thought that this is " Just the Way Harley's Are ". But now I'm Really Wondering. You know it's freaking embarassing when your at a steeler on a saturday or bike rally and you go to start your bike and it pulls that crap on you.
Anybody else have this happen to them. Is this Normal or do I need to talk to my dealer about it. Your thought comments please. Thanks......
LV
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
cantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to behold
I've had that happen....more often after the conversion, I believe (higher compression), but even with this bike....
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
dave's Avatar
dave dave is offline
dave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura about
Having the starter "hang" happens to me as well - not very often though. And just as you say, the next "hit" on the starter works. This happens even less now that I always put Lilybeth on a battery tender when she's in the garage.
Dave Funk
Lafayette, California
2004 1200 Custom (Vivid Black)
"Lilybeth"
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
Same thing happens to my 05/1200C. Never when cold, only occasionally when hot. Next hit on the starter button and it cranks right over and starts. I've checked everything I can think of - battery, cables, starer current draw, starter reley - all check out good. I think it is just a result of the higher compression motor and the amount of fuel in the cylinders.
SEMJPM
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura about
Check battery condition..... and ALL connections as SEM has done... that means REMOVE, clean and refit..... mot just wiggle to check they are on
but it's not really a major problem ....
Ya should try Twinkies with a 95+" kit and more compression ... they chew thru starter clutches
Even put internal tooth lock washers on battery cables (both ends), starter to battery cable and starter to ground. Same result, but not a big issue.
SEMJPM
Old 20th February 2006
Bow6's Avatar
Bow6 Bow6 is offline
Sportster/Buell Model: 883C
Bow6 is an unknown quantity at this point
Reminds me of a weak (bad) cell in the battery acting up...
jettech777's Avatar
jettech777 jettech777 is offline
jettech777 is an unknown quantity at this point
Same thing with my 05 1200c, just once in a while. I think Ill just live with it.
rider1951's Avatar
rider1951 rider1951 is offline
Other Motorcycle Model: Suzuki DL1000
Other Motorcycle Year: 2002
rider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the rough
Mine does the same thing. I had a 76 R90/6 BMW that would do the same thing. So far it hasn't been a big deal.
Impact Blue 1200 Custom, Gronk's mod stock exhaust, Ram-Flo 400, 45 slow, N65 needle, 175 main, HD detachable windshield and rear rack/ back rest, lay-down license plate, Mustang wide vintage, Progressive 13 1/2" 418s and Progressive fork springs w/ Belray oil, Superbrace,
DaleG DaleG is offline
Sportster/Buell Model: Sportster Custom
Other Motorcycle Model: Street Glide
Other Motorcycle Year: 2007
DaleG is on a distinguished roadDaleG is on a distinguished road
I believe I was the one that started a thread about that over a year ago. I have a 2004 1200C. It still occasionally seems to hang, but it always starts. I asked the dealer, and he said it was probably compression.
