Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Progressive Suspension
Dead Creek Cycles
Sportster Specialty
Old 18th November 2004
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
Default Gas Tank Crooked
I don't know why it's taken me so long to ask this, but here it goes.
I have a 2004 1200R, and the tank almost looks like it's on the nike crooked. The fuel cap doesn't seem to be in line with the center of the bike - it's sits a little off to the side. I only notice this when I'm sitting on it, not while I'm off it and looking at it, but I also haven't really tried to look yet.
Is it actually crooked? If so, is it adjustable?
Old 8th December 2004
skooter's Avatar
skooter skooter is offline
Sportster/Buell Model: XL 1200S
Sportster/Buell Year: '97
skooter will become famous soon enoughskooter will become famous soon enoughskooter will become famous soon enoughskooter will become famous soon enoughskooter will become famous soon enoughskooter will become famous soon enough
It is not adustable!
Welcome to the fine world of Harley Davidson! My 97 1200s came from the factory with the tank cocked to the right about a 1/4". Has been that way ever since. Did you expect an accurately made bike from HD MoCo?
Ya right! they haven't built a bike that hasn't had something off centre in their entire history. Check the level on the rear turn signal lights on Heritage next time you get close to one. As a matter of a fact just look real close to any Harley that you find.
Don't worry about it. The dealer won't either and the factory sure doesn't.
rottenralph's Avatar
rottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant future
Tell the stealer to fix it. That is what the warranty is for. If it is not in warranty it is nothing a large amllet won't fix. A couple of whacks and it will be straight. Just move the tabs in the direction they need to go.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
skooter's Avatar
Hey take a close look at the rear mounting tab on your seat. It is off set about 1/8 of an inch. This will give you something else to complain about when you take her back to the dealer.
Similar Threads
Gas Tank Crooked???? xl1200r Rubber Mount Sportster Motorcycle Talk (2004-2006) 4 20th May 2007 14:04
Found the bottom of my gas tank! gilx Sportster Motorcycle General Discussion and Problems 12 5th May 2005 19:45
Removing reflectors from fender Geek Sportster Motorcycle Custom Finishing 8 9th March 2005 01:27
Looking for a new gas tank tmcelrea Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 25 1st January 2005 23:22
Tank Expansion or Horizontal Stretch Speedy818 Sportster Motorcycle Custom Finishing 4 1st January 2005 22:39
