The Sportster and Buell Motorcycle Forum CV Performance
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Sky Smith Insurance
Get Lowered
Don's Cyclewear
Old 4th June 2008
ash ash is offline
Sportster/Buell Model: XLH883
ash has disabled reputation
Default Big Sucker
What do you guys think 'bout this for the blow-by problem for the B.S. What if I drilled and tapped the "arms" (underneath) of the backing plate for a couple of threaded hose fittings? Then plug the holes feeding the oily mist filter side, so the oil is routed to hoses and tees attached to the aformentioned fittings under and out of the bike. Any feedback?
thanks,
ash
Old 4th June 2008
rodhotter rodhotter is offline
rodhotter has disabled reputation
just like the screamin eagle setup on the 883 i rejetted this weekend, doherty powerpac with horshoe breathers rules, just plug the inlets to the carb and try it good luck
Old 4th June 2008
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
Sounds workable. Might as well try it; if you're unhappy with the BS as it is, what've you got to lose?
Folkie
'The green machine'
