The Sportster and Buell Motorcycle Forum Licks Tanklift
Go Back   The Sportster and Buell Motorcycle Forum > GENERAL AREA > Car Talk
Dead Creek Cycles
NHRS Performance
Marks Moto Gear
The Dart Flyscreen
Speedway Instruments
Old 5th March 2006
GOTWA's Avatar
GOTWA GOTWA is offline
GOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enough
Default Found It, I think...(Electrical Trouble-Truck)
So for the past couple weeks the starter on my old '76 Ford hsa been acting up. Thuncking every now and then and maybe a slight hesitation on disengagement. Nothing terrible or consitant just faint and every now and then. But enough to make me hear it. I don't drive the truck daily so I figured when I got a little free time I'd toss a new starter in it.
Bu as in most things mechanical, the truck made the decision for me and decided I wasn't going to wait as long as I thought I was. Went out a few days ago to start it and all I got were rapid clicks. So figured the starter gave up the ghost.
And that is where I would have started if I hadn't of tried her the next morning just out of curiousity. She was completely dead. No juice no way. So then I got to thinking the battery went tits and maybe the weakening battery had been the cause of the starter issue.
Had to work so no real time to mess with it but I did pick up a new battery. Figured even that wasn't the issue I could stand to put a new one in the Bronco so it wouldn't be a waste of money either way.
But before I tossed ina new battery and risked ruining it somehow I decided to jump the truck off the Bronco and see what happened. Got her fired, ran her around to get her all charged up and decided to see what would happen after she sat for a while. As I suspected, 12 hours later she barely had any juice.
So now I'm thinking either the alternator went tits or I got a draw somewhere. Again I turned to my wrench-wise brother in law just for his take on it. His advice was to charge the battery and test for a draw, which he explained to me how to do. See, I hate electricity. It confuses me and beyond the most rudimentary understanding I know jack damnit about it.
Well, the charger wouldn't charge the battery. Nope, nada, ain't gonna work says the charger. Hooked the charger up to the Bronco just to eliminate it as a potential problem and it worked fine. So, why no chargey Joe???
Set the new battery in and did the draw test, sure enough, I had one. Oh yay. First disconnected the alternator in hopes it grounded itself out. Nope, still got the light. Then it was pull each fuse one by and test after each. Got a light on every one. Humph. Pulled the only in-line fuses I could find and still no dice. Damn.
Pulled the two heavy wires off the positive side of the solenoid, put one and the cable back on. No light! Pulled that one off, put the other one on, got a light. Now where getting somewhere. Only that particular wire feeds multiple things and disappears into thick bundle of well wrapped wiring. So, disconnected the coil, still got a light. Unplugged the ignition, yep still got a light.
Damn...
So it was start ripping off electrical tape and tracing the wire. First stop, the condensor. Disconnected it and hey no light! Pins looked terrible so I cleaned up did the magical, fix everything, quick blows on the plug, reconnected and still no light!
Hooked everything back up and she fired right up!
Now, I'm not positive (no pun intended) I actually fixed the problem or just isolated it. I'll run it by my BIL later. Likely he'll tell me to change the condensor which is no biggy. I'm just a little stoked because I am so not good with electrical troubleshooting and all the quick stuff turned up dry.
So hopefully I got it. And more importantly I learned some new things and gained a new skill or two. And that is always a good outcome!
Gazza would be proud of me.
Old 5th March 2006
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to beholdthatbikerguy is a splendid one to behold
If i could have that kind of success when i worked on autos... it always ends up at someones shop.
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Old 5th March 2006
RedRider RedRider is offline
RedRider has disabled reputation
Sounds like ya got it nailed down, Erik.
Good job!
Old 5th March 2006
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura about
Start the truck with the multimeter accross the battery terminals....
See what it drops to when ya start it....
Then bring the revs up and see what it reads.... it should be over 14 volts from memory (too long since I've worked as a car mechanic) when ya get some revs up...
If not, then the alternator/regulator area has an issue....
Old 6th March 2006
GOTWA's Avatar
Just had a re-read and excuse my use of "condensor" in my original post. Reckon I had it on the brain when I typed as I planning to do points, rotor, etc. in the next few days.
I should have been typing "relay" instead. The problem was an insulated relay, maybe for the horn, didn't bother tracking the wires out of it. At any rate, looks like it was shorting out from the corrosion. Just went out and hit the key and she fired right up.
So uh, who wants to come over and change my front wheel bearings?
Old 6th March 2006
a45junkie's Avatar
a45junkie a45junkie is offline
Master Bike Builder
Sportster/Buell Model: XLH883/1200
Sportster/Buell Year: 96
Other Motorcycle Model: CX500
Other Motorcycle Year: 84
a45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nice
for the price of a relay i would just put in a new one
96 XLH883/1200
BUB Reinhart 2-1 exaust fitted with supertrapp muffler 24 disks
big sucker stage one
progressive suspension
Old 6th March 2006
DM-SC's Avatar
DM-SC DM-SC is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Heritage Classic
DM-SC is an unknown quantity at this point
Yeah, not a bad idea...
Some minds are like concrete..thoroughly mixed up and permanently set!
2004 Heritage Classic - Ness Big Sucker, V&H Longshots, PCIIIUSB
Former Sporty Pilot...Now riding a "Road Sofa"
Old 6th March 2006
GOTWA's Avatar
I agree and will. Just excited I tracked down the problem. I was getting a little intimidated when nothing was working.
