17th June 2008
Posts: 115 Sportster/Buell Model: XL Sportster/Buell Year: 99
Long warm up problem
My sporty takes forever to warm up if not started for a few days or so. I mean about 7 or 8 mins. Then, after warming it up for a while, it'll sputter until I pop it in neutral and open the throttle to clean it out.
Also, it'll 'pop, pop, pop' if I roll off the throttle and cruise in gear (like small backfires). I think I need to re-jet, but not sure.
Any ideas? Just a tune up maybe?
17th June 2008
Posts: 3,246 Sportster/Buell Model: xlh Sportster/Buell Year: 94
What do the Plugs look like ...?
Is your Choke Sticking *On*...?
[SIZE="3"][B]IN MEMORIAM:[/B][/SIZE]
[SIZE="2"][COLOR="Red"]VOTE MR JIMI FOR HOTTEST MEMBER...!!![/COLOR][/SIZE]
"Money Wont Buy Happiness, But it Sure would make Misery More Bearable"
But, Its Ok...cuz *I have a Disorder.*
.....Nemo Me Impune Lacessit
'94 Xlh 883 converted to S&S Hot Set-up 1200 kit, 9.2 to 1 comp, Andrews N6 cams, adjustable P-rods,Super E, Cycle Shack M's w/Gronk Baffle Mod, S&S Heads, Thunder Jet, Sifton Bombsight, SE Ign, Progressive 4800-Rear, White Bros Lowering Kit-Front
:pgrflag:
17th June 2008
Havn't checked plugs in a while. Choke not sticking on, I have to hold it out as it'll push itself back in otherwise.
17th June 2008
fisherofmen
Posts: 4,459 Sportster/Buell Model: 1200 C Chopper Sportster/Buell Year: 2005 Sportster/Buell Model #2: 1200 R Sportster/Buell Year #2: 08 Other Motorcycle Model: XLH 1000 Other Motorcycle Year: 79
sounds like it is really lean. if you have had the bike awhile and it didn"t do it before.i would clean the carb blow out all the jets good. sometimes they gum up over the winter.you can check and see if it accelerates good with the choke on. then that is where i would start
LIFE IS SHORT PRAY HARD!!!!!
CURE FOR INSOMNIA. QUIT COUNTING THE SHEEP AND TALK TO THE SHEPHERD.
always a work in progress!!!!!!!!!!!
Uploaded with ImageShack.us
17th June 2008
Another thing is when it's warming up, if I roll on the throttle, it'll just die; I guess that does sound like the jets are clogged. It's just never done this before. I guess I'll spend this weekend given it a tune. Thanks to all.
17th June 2008
Posts: 2,340 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2005 Other Motorcycle Model: Suzuki GSX750ESG Other Motorcycle Year: 1989
Slow to warm up usually means too rich, not too lean. Lean motors run hot, rich motors run cold.
It could just be that it is partially flooded as you say this only happens when it hasn't been started for a while - I'm guessing it takes a few cranks to get it started which could easily overfuel it.
If it runs ok otherwise then I wouldn't worry.
Cheers,
Brett
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
17th June 2008
Bike Builder
Posts: 1,873 Sportster/Buell Model: FXR Sportster/Buell Year: 1994
If by slow to warm up you mean cold blooded, it's lean.
Rich bikes operate very well when cold. Lean bikes spit and sputter when cold.
17th June 2008
Brass Nut
Posts: 30,731 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
That could be an exhaust leak.
Folkie
'The green machine'
18th June 2008
But it's fine when it's 'warm'.
Based on what you've all said above, I think it's rich. It'll start right up w/ the choke out, but takes forever to get 'warm'. Then, it's like I have to shift to N and roll the throttle back hard, like blowing out the stacks after idling for a while (at least it's like that on a ship anyway!).
That said, I just have to get a tune up and re-jet? I did change pipes a while ago. Either way, she needs a tune (been a while). I hate to take it to the shop ($), so I usually use carb cleaner, clean the k&n, change the plugs, oil and oil filter, and flush out my in-line fuel filter. Any other points you can think of? Guess I can just Google it, too.
Any more pointers are greatly appreciated! This site is great.
18th June 2008
Tune-up....Yes, and there aint much you need to do for that.
Rejet...No, at least not until you give it a tune-up. Your looking to open up a whole can of worms if you start messing with the Jetting until you at least LOOKED at the plugs.
In fact, get it out of your head until your POSITIVE you dont have any other issues going on; Exhaust/Intake leaks, Fuel Filter, Air Filter and...PLUGS
This is easy stuff for the DIY'er, a good place to start for the Newbie.
| Thread Tools |
| Display Modes |
