NRHS Performance Long 2
Sportster Specialty
Foxcreek Leather
Old 18th April 2006
tprJJ49707's Avatar
tprJJ49707 tprJJ49707 is offline
Sportster/Buell Year: 1985
Other Motorcycle Model: Indian Sport Scout
Other Motorcycle Year: 1940
tprJJ49707 is an unknown quantity at this point
Default Crane HI4 settings
Got the ignition out of drawer last night and read accompanying paperwork,
I am looking for input as to setting rev limits...and also wonder what would be considered optimum advance (on upper filpot).
Old 18th April 2006
FSZEKE302's Avatar
FSZEKE302 FSZEKE302 is offline
US NAVY Vet, ADR2
Other Motorcycle Model: FXD SuperGlide
FSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the rough
I set mine at 6000 rpm limit, as close to half way between min[5000] and half range [7000]. I set my timing according to the instructions for using a back up timing light. Used 35 degrees and set pot at max advance. I have always used 93 octane and I get no detonation with it. With stock ign I had to use 93, I'm going to try mid grade soon, since I can take some advance out with the pot. Interested to see how you come out. Let us know your results please.
ZEKE] Old and Proud 1994 XLH [Black of Course] " A fear of weapons is a sign of retarded sexual and emotional maturity " -Sigmund Freud http://xlforum.net/photopost/showgal...r=3484&cat=500
US NAVY Vet, ADR2
Old 18th April 2006
md2420's Avatar
md2420 md2420 is offline
Sportster/Buell Model: XLH Ironhead Sportster
md2420 is an unknown quantity at this point
thought i'd jump in and get ur take on going with the Crane (or some other electronic ignition) vs. the points......I seem to burn through points (more often than I think I should)....also getting some backfire on my 74 XLH....this a points problem? or as u eluded to a FUEL/octane issue? I'm currently running 91 or 92 (whatever is the highest at my local pumps)....can't say that i've seen 93 around here (AZ)
thx!
md
Old 19th April 2006
Two things that cause backfire are exhaust leaks and lean carb settings. I would check for exhaust leaks first as this is easy, and you can never get a good tuneup with exh leaks.
Put 1/2 ounce of oil into each cyl thru the sparkie holes and run it at idle. You will get lots of smoke for about 5 minutes. Any not from the exhaust ends is a leak which must be fixed.
May as well check for intake leaks while you are at it. Spray WD40 around the cyl-intake-carb joints while idling. Any change in RPM is a leak which must be fixed.
Then richen up the pilot screw setting by 1/4 turn and see if there is a difference.
I have the Crane Hi-4.
Old 19th April 2006
md2420's Avatar
thx IronMick....good to know....I've put another post re: my Bendix carb and once I have that worked out, i'll move on to the items you suggested (gotta get it running before I can test for leaks
md
