The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 3
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Primordial Cycles
Licks Holiday
Get Lowered
Old 24th April 2006
Jimbo999's Avatar
Jimbo999 Jimbo999 is offline
Riding with Angels
Sportster/Buell Model: Sportster XLH 883
Sportster/Buell Year: 1988
Jimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the rough
Default No more Sportrans
I read a thread a week ago about Sportrans primary lube and I just confirmed
it today.
Yes.........Harley's discontinuing that fluid. I asked the stealership parts guys
today at Route66 in Tulsa and he showed me the status, it says "Obsolete" in their inventory database.
They still have 6 cases of it in stock........I bought 2 qts.
Just thought I'd pass this info along.
Try n' catch the wind
Stage 1
Taxes Paid
Blue Loctite is your Friend
Old 24th April 2006
skratch's Avatar
skratch skratch is offline
skratch has disabled reputation
been replaced with formula+
got some to do my 10k service, haven't got around to it yet.
If he runs, he's a terrorist. If he doesn't, he's a well disciplined terrorist.
Old 25th April 2006
Jimbo999's Avatar
Riding with Angels
1 time bump.
Old 25th April 2006
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Yep, I was at LowCountry HD in Charleston SC this past weekend and picked up oil, filter and primary lube.
They were out of SportTrans and I got Forumua +. My local dealer still has SportTrans but they say when the stock is gone it's gone....
Old 25th April 2006
wabiker's Avatar
wabiker wabiker is offline
Sportster/Buell Year: 94
wabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to all
......soooooo..... Are they saying we can use Formula X in the older bikes or do we have to shop somewhere else?? Or does it matter??
[SIZE="3"][B]IN MEMORIAM:[/B][/SIZE]
[SIZE="2"][COLOR="Red"]VOTE MR JIMI FOR HOTTEST MEMBER...!!![/COLOR][/SIZE]
"Money Wont Buy Happiness, But it Sure would make Misery More Bearable"
But, Its Ok...cuz *I have a Disorder.*
.....Nemo Me Impune Lacessit
'94 Xlh 883 converted to S&S Hot Set-up 1200 kit, 9.2 to 1 comp, Andrews N6 cams, adjustable P-rods,Super E, Cycle Shack M's w/Gronk Baffle Mod, S&S Heads, Thunder Jet, Sifton Bombsight, SE Ign, Progressive 4800-Rear, White Bros Lowering Kit-Front
:pgrflag:
Old 25th April 2006
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
Yeah...I haven't even seen this "Formula +" stuff - is it the HD replacement? It's not Synthetic, is it?
Old 25th April 2006
Shu's Avatar
Shu Shu is offline
Shu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of lightShu is a glorious beacon of light
Actually I think SportTrans was a synthetic blend anyway.
Shu
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 25th April 2006
xl1200r's Avatar
I did not know that...learn something everyday.
Old 25th April 2006
FORMULA+ Transmission and Primary Chaincase Lubricant
Developed with a proprietary mineral basestock formula, TESTED-CERTIFIED by Harley-Davidson® Motor Company. Formulated to provide lubricity for the anti-wear requirements of transmission gears. Formulated to maintain the coefficient of friction for proper clutch operation and provide adequate lubrication to the primary chain. Approved for use in all stages of transmission and primary chaincase life. Not for use in the crankcase as a motor oil.
99851-05
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
1 Quart
Formulated for use in Harley-Davidson Transmissions (except VRSC models) and the following Primary Chaincase applications: '71-later XL, '83-'84 XR1000, and '84-later Big Twin models with wet type diaphragm spring clutch.
MSRP US $5.95
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 25th April 2006
As long as Harley has given it the offical "Thumb's Up", it seems as it will be just fine to me.
