27th July 2008
Brass Nut
Posts: 30,744 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
Originally Posted by drcstang
You can always send a PM to a mod to suggest a thread gets made a sticky for easy reference.
I've just PMd Chuck to suggest exactly that.
Folkie
'The green machine'
27th July 2008
OzChick
Posts: 2,361 Sportster/Buell Model: XL 1200N Sportster/Buell Year: 08 Other Motorcycle Model: Trumpy
Hey Dan, another thread with great pics and explanation!  Thanks for sharing; looking forward to hearing more about how they perform on the road.
OzChick ~ Riding Nyx
Only a biker knows why a dog sticks its head out the car window...
My Photos: www.photobytrace.com
27th July 2008
Posts: 4,801 Sportster/Buell Model: 1200 Low Sportster/Buell Year: 2007 Other Motorcycle Model: Yamaha FZ1 Other Motorcycle Year: 2008
Here is the original thread.
http://xlforum.net/vbportal/forums/s...ad.php?t=51610
DRC be carefull durring full on brake tests with that MC, you may run out of lever travel.
Regarding engine mods, it all depends what you are driven by......
Bling, bragging rights, silky smooth power delivery, a little more peak power, violent power delivery,
traction or wheelie limited acceleration, a sound that just drips testosterone or peace of mind that
everything is as perfect as you know how to make it.
When the racers get done doing the impossible the engineers get a chance to correct the errors in the model.
***My other addiction, running Megasquirt EFI ***
27th July 2008
Brass Nut
Originally Posted by whittlebeast
Which m/c do you recommend Andy?
27th July 2008
The 1/2" version works great. The 9/16" requires a little too much hand force.
27th July 2008
Posts: 656 Sportster/Buell Model: 1200c Sportster/Buell Year: 96 Other Motorcycle Model: harley flhx Other Motorcycle Year: 07
thanks for the write up. looking to upgrade my brakes so i'll be coming back to this post. thanks.
[IMG]http://i122.photobucket.com/albums/o242/rickxx/sporty210-24-10.jpg[/IMG]
my '96 1200 Custom
27th July 2008
Brass Nut
Thanks.
27th July 2008
Getting Hammered!
Posts: 5,174 Sportster/Buell Model: 883L (sorta) Sportster/Buell Year: 2007 Sportster/Buell Model #2: 1200R Sportster/Buell Year #2: 2007
Originally Posted by ReddTigger
do you know if this will work on a Solid Mount ?
I should Specify. Pre 2000 solid Mount..
Anthony - Hopefully someone else can answer your question. If I had to pull an answer outta my azz I would *guess* not.
Originally Posted by slickdog
Good Write up, Better than Haynes or Clymer!!
One Thing I usually do is take the Master cylinder cover off and cover with clingfilm then bolt it back on, while removing calipers, this creates a bit of a vacuum and stops the fluid coming out.
This time I didn't care, but if I ever have to pull things apart I'll definitely try the cling wrap.
Hey man...that link is in the very first line of this post just have to click the word " here". I want to make sure you and rolnlow get credit for this idea...I just bolted on the parts you guys talked about while taking pictures.
And yes, I have discovered it's pretty easy to run out of travel. I'm just not sure what I'll do with more travel...I suspect lock up the front tire!
I've read that other thread about a bazillion times...I would have sworn your recommendation was 9/16. Guess I gotta go back and re-read it, again.  Did I mess anything else up?
Folkie - Clearly listen to Whittlebeast and not me...  And apparently Bert got around to making this a sticky before Chuck.
Screw Loose Dan
Pegs down for BryanEOD...you'll be missed but not forgotten.
Thanks to all those that serve and especially all those that have given all.
"Life should be lived"
1st August 2008
Posts: 657 Sportster/Buell Model: XL 883/1212 Sportster/Buell Year: 2005
Welcome to the club brother. If you haven't already, you should install some Progressive fork springs. Those V-rod brakes will make the front end dive something fierce.
Raising Hell since 1977.
19th August 2008
Getting Hammered!
Three week (or so) update. Haven't gotten too much riding in, but did get to try the brakes out some more. I also switched out the ME880 tires for Avon Venoms. I mention that because I think the Avons have a little more control at the point at which the front tire locks up.
These brakes have just an incredible feel and stopping power. I guess at a lot of levels it's subjective, but the confidence these brakes inspire can probably get one into a lot of trouble. I've never heard my front tire howl nearly as much as it has in the last few weeks...
Now that the pads are completely bedded in and the lines fully bled, the brake lever travel is tolerable with the stock master cylinder. It's certainly not ideal and Whittlebeast's recommendation of a 1/2" MC is probably really needed.
Well, my front-end is just about bottomed out just riding down the street, much less pulling the brake lever (damn low...whose the idiot that buys a low model!  ). If your into adrenaline, my bike's current setup is the ticket...pulling hard on the brake with the front forks completely collapsed going across bumps gets REAL exciting. I'll be buying new 883R forks sooner or later. Debating on the Works springs or not, but I think I'll just try the stock ones to begin with.
Switching out to the blackened 883R forks will also give me the opportunity to put a dual caliper setup on. I realize with this Brembo single caliper setup I really don't need the second caliper...but I just can't resist for some reason.  Call me a poser if you will.
I have the stock Master Cylinder that comes on the baggers with the dual Brembo's. Anyone know the part number off-hand for the right hand caliper on a late model VROD?
| Thread Tools |
| Display Modes |
