19th August 2008
Brass Nut
Posts: 30,440 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
Originally Posted by drcstang
Now that the pads are completely bedded in and the lines fully bled, the brake lever travel is tolerable with the stock master cylinder. It's certainly not ideal and Whittlebeast's recommendation of a 1/2" MC is probably really needed.
Anyone know what MC that would be? Would the MC from the dual disk Sporty be the right size?
Folkie
'The green machine'
19th August 2008
OzChick
Posts: 2,324 Sportster/Buell Model: XL 1200N Sportster/Buell Year: 08 Other Motorcycle Model: Trumpy
If your into adrenaline, my bike's current setup is the ticket...pulling hard on the brake with the front forks completely collapsed going across bumps gets REAL exciting.
 Surely there are better ways to get thrills Dan!
I'll be buying new 883R forks sooner or later.
Hopefully soon by the sounds of it!!!
Debating on the Works springs or not, but I think I'll just try the stock ones to begin with.
I can recommend the works springs in the low forks... but if you are getting R forks shortly then I guess try them first and see; considering the air valves still??
OzChick ~ Riding Nyx
Only a biker knows why a dog sticks its head out the car window...
My Photos: www.photobytrace.com
19th August 2008
Getting Hammered!
Posts: 5,070 Sportster/Buell Model: 883L (sorta) Sportster/Buell Year: 2007 Sportster/Buell Model #2: 1200R Sportster/Buell Year #2: 2007
According to my 2007 Service Manual, the dual caliper setup is 1/2" so that should be right. I remember a discussion in Whittlebeast's brake thread that someone mentioned the earlier rubbermounts had different size MC's.
Sure there are! When you coming to the States again??
Just gotta wait for the pay checks to catch-up to the OT worked!
Yeah, I kinda have my mind set on the 883R forks. More black = faster bike!  And I'll have the option to put the duals on.  I'll probably throw the air valves on the 883R forks before mounting everything.
Screw Loose Dan
Pegs down for BryanEOD...you'll be missed but not forgotten.
Thanks to all those that serve and especially all those that have given all.
"Life should be lived"
19th August 2008
Brass Nut
Thanks Dan, that's useful info.
19th August 2008
Posts: 81 Sportster/Buell Model: xl883 Sportster/Buell Year: 2007 Other Motorcycle Model: R100gs Other Motorcycle Year: 1991
'00 to '03 Sportsters used a 9/16 MC with a single disk (4 piston Hayes). Same as the BT's. I dont know the piston size on the Brembos however. There are a lot of these MC's on ebay.
19th August 2008
Posts: 4,794 Sportster/Buell Model: 1200 Low Sportster/Buell Year: 2007 Other Motorcycle Model: Yamaha FZ1 Other Motorcycle Year: 2008
There were MC changes for 2007 and later. Everything went one size smaller after the 2006 models to make it less lever effort to lock up the front tire. That change resulted in more lever movement for the same braking force at the tire.
Regarding engine mods, it all depends what you are driven by......
Bling, bragging rights, silky smooth power delivery, a little more peak power, violent power delivery,
traction or wheelie limited acceleration, a sound that just drips testosterone or peace of mind that
everything is as perfect as you know how to make it.
When the racers get done doing the impossible the engineers get a chance to correct the errors in the model.
***My other addiction, running Megasquirt EFI ***
19th August 2008
OK, here's a silly question maybe - so are you saying when running a 4-pot BT caliper on a 2007 or later
A. order a 1/2" Roadster MC - for 2007 models?
or
B. order a 2006 1/2" Roadster MC?
or
C. Order a 2006 9/16" non-Roadster MC?
I'm guessing A or B?
19th August 2008
2007 roadster or 2004 - 2006 single rotor MC 1/2" dia or 12.7mm
19th August 2008
So they didn't change THAT MC - just the MC on the non-dual rotor 07s???
Kev
19th August 2008
Brass Nut
Oh right. So the m/c I've already got is ½". So I could fit one of these V-Rod brakes, and it should work well with my existing m/c?
| Thread Tools |
| Display Modes |
