The Sportster and Buell Motorcycle Forum Licks Tanklift
NRHS
Sportster Specialty
Flying Piston
Flying Piston
Old 6th May 2006
95xlcustom's Avatar
95xlcustom 95xlcustom is offline
Sportster/Buell Model: 1200 xl
95xlcustom has disabled reputation
Question noise HELP
my bike has a clicking noise in the front pulley area it ts sound like it coming from inside. and it also sounds spring loaded. i took a long screw driver and had my buddy spine the rear tire when it was up on a jack to locate the noise. and it seems to be some were around the starter. it does it about 2 times for every full rear tire revolition.
Old 6th May 2006
95xlcustom's Avatar
the bike shifts and drives fine. i changed the pramary oil just to see if that was it. the chain seems good.
Old 6th May 2006
95xlcustom's Avatar
ttt....................
Old 7th May 2006
95xlcustom's Avatar
anyone. ive changed oil and primary it seems to only do it when the bike it warm.
Old 8th May 2006
95xlcustom's Avatar
shes fixed
Old 8th May 2006
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster!!
Sportster/Buell Year: 01
xllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant future
What did you do to fix it?
RTFS
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
