4th June 2006
Posts: 451 Sportster/Buell Model: XL883L Chopper Blue, Baby Sportster/Buell Year: 2005
1250>883 with Stock...
...cams, heads, ignition etc...?
Hey Dan (and ?) I noticed that on your site you have a dyno readout for a "stock" based 1250. My question is can you do the 883>1250 with stock everything, then upgrade as you go.
My '05 883L will only have "Gronk Mod" mufflers and your 2" centered A/C and I am thinking of doing this, my biggest concern is the stock ignition.
Also the biggest reason I choose a 883L was the natural/silver cases, jugs and heads. To keep the look closest to stock would I use the natrual or silver powder coated kit???
Thanks for your valuable time....looking forward to being a customer.
Scott
:pgrflag: [FONT="Comic Sans MS"]SPORTSTER...by choice![/FONT]
4th June 2006
Posts: 12,643 Sportster/Buell Model: xl1218rr turbo Sportster/Buell Year: 1993
Not Nhrs but your stock ignition is fine. That would be one of the last places I would spend money. The 1250 kit will give you the biggest bang for your buck by far. Now wait and I am sure they will answer.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
4th June 2006
A Million Facts & Figures
Posts: 5,877 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
These are in chronological order, with the most recent configurations on top. Done on a 2004 XL883.
Kinda messed up because there was a change in the pipe and cams I was using that I did midstream. The E cams were too noisy and the CS pipes were reverting in the middle. It really changed the powerband as you can see.
4th June 2006
Posts: 283 Sportster/Buell Model: 883 XL 1200 Conversion Sportster/Buell Year: 2004
I am having problems navigating on your site. I tried going into the Products link so I could look at all the products you have listed in the dyno sheet. I was looking for the HSR42 and Twin Tec in particular. I am familier with the rest enough to figure them out. I am also curious how much more power you would get with head off of a 1200, Buel or your perfomance heads compared to the 883 heads. I don't plan on having work done on my heads as I figure by the time I get the work done and the cost I would probably get the same or close to the same from stock Buel or 1200 heads. I have an 04 XL883 by the way.
2004 883 XL Pretty basic for now.
Tank/paint, A/C, Exhaust, Drchaos No-jet kit, Detachable Sissybar, Rear Turnsignals Relocate, 18" Ape's, 1200 conversion, mild head work, Mustang seat, Chrome, Chrome, and getting more Chrome.
4th June 2006
if i may add, your looking at numbers. you need to feel a 1250 to believe the difference. from a 883. i thought my 883 was quick now it feels like a monster with no head work just cams.
5th June 2006
Posts: 10,212 Sportster/Buell Model: 07 883 X2 plus 5 Buells Sportster/Buell Year: 2007 Sportster/Buell Model #2: 92 Sportster/Buell Year #2: 96 Other Motorcycle Model: and 2 more!!
Everything depends on the total of your components. Cams will not give more power if your heads can't flow. That is why we say do not install cams if you have stock 883 heads as they will be a waste. Now do some headwork or install better heads then cams help out tremendously.
Same thing with the ignition. If you don't have cams and heads that can make power in higher rpm ranges then an ignition will not be of much use.
Dan
NRHS
303-702-1600
www.nrhsperformance.com
The truth is out there. It's only a matter of time!
5th June 2006
Posts: 2,402 Sportster/Buell Model: Sold Sportster/Buell Year: 2005
Dan, do you have a similar graph comparing a plain 883 > 1212 conversion? (and maybe the more extensive conversions too)
2005 Black 883XL / NRHS 1200, 9.5:1 Comp, .497 Cams, SE A/C & Pipes, Jagg oil cooler
_________________
Don't throw your pearls to swine! They will trample the pearls, then turn and attack you.
Well ... that explains a lot.
5th June 2006
No sorry,
We have only done it as a 1250. Just not enough time to do every conbination.
5th June 2006
Thanks anyway. That is some drastic horsepower increases you've got going there.
5th June 2006
We do very good work!!
| Thread Tools |
| Display Modes |
