Sky Smith Insurance
Biltwell
Progressive Suspension
Ricor Shocks
Old 9th June 2006
Melvin J's Avatar
Melvin J Melvin J is offline
Sportster/Buell Year: 1965
Melvin J is an unknown quantity at this point
Default Oil
I'm in the final stretch of my build. Finally! Just wondering if I can prime my oiling system by kicking the bike over or if I have to actually start it to get the oil flowing. I kicked it over a few times to see if it would suck oil from the tank but no luck so far. I would think the pump would still work but how many times do I need to kick this damn thing to get oil through the whole system if thats the case
Thanks
Mel
Old 9th June 2006
jamman's Avatar
jamman jamman is offline
Other Motorcycle Model: A Hawg
Other Motorcycle Year: 06
jamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the rough
till it gets "prime"
Old 9th June 2006
garbiker's Avatar
garbiker garbiker is offline
Sportster/Buell Model: 883
Sportster/Buell Model #2: old ironhead .
Sportster/Buell Year #2: ???
Other Motorcycle Model: 900 kaw z1
Other Motorcycle Year: 73
garbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the rough
I would pull the line at the pump and let some come out as it can air lock and not pump then kick it a couple of time then fire it watch the return on tank . just loosen the clamp and pull on it to let the air out of the lines and oil comes out or you can starve it before it primes. good luck. gar
Old 9th June 2006
I'm with gar.
Old 9th June 2006
Melvin J's Avatar
Thanks guys, I figured it was probably air in the lines I'll give a try tomorrow I'll let you know how it goes.
Thanks again
Mel
