The Sportster and Buell Motorcycle Forum Figure Machine
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Dead Creek Cycles
NRHS Performance Long 2
NHRS Performance
Old 20th February 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
cantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to behold
Default Round A/C
I like the round A/C that I saw on somebody's bike here...
I have an 02 Custom and I LOVE that look..
Can anyone tell me about them?
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
It's SE part# 29008-90a which is getting hard to find because they have been disco'd. Just get a head breather kit and a round ac cover and your good to go.
Arlen Ness and Doherty machine will also have a couple out soon as well.
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura about
I've got a second hand one here
Not much good to you tho...... but I can take a pic to show ya what it all looks like if ya really want....
cantolina's Avatar
Why isn't it any good to me?
cantolina's Avatar
Seems they only fit up to '99???
Old 21st February 2005
stevo's Avatar
By the time I send it to you and add the postage on you probably coulda bought one new over there
You would have to use some form of bracket to hold it anyway.......
and they'll fit ALL sporties and big twins with the right bracket......
Ya just need the seperate breathers, which is not a bad thing anyway.
xena's Avatar
xena xena is offline
Assistant Administrator
xena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant futurexena has a brilliant future
Cantolina I'll be setting up my bike with the round one as soon as the breather kit gets here.
Turbota has the same one on his bike and he gave me the parts list. I called chicago harley, hales, and several other HD dealers but nobody had the ac kit in stock. Last week I was able to get one on ebay brand new in the box though.
Here's the part #'s Bota gave me. I don't know if anything would be different on your 02'.
Screamin’ Eagle Air Cleaner Kit
Harley-Davidson P/N 29008-90A
Air Cleaner Cover (Black)
Harley-Davidson P/N 29548-98
Air Cleaner Center Screw
Harley-Davidson P/N 29703-00
Crankcase Breather Kit
Drag Specialties P/N 2110-0316 Harley-Davidson P/N 29281-91T (same item)
Air Cleaner Support Brace
Drag Specialties P/N DS-289062
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A Xena's Black Panther - Turbota Hybrid Map
My 1212 Conversion Thread
XL Forum Members Map
Old 24th February 2005
xena's Avatar
Default round air cleaner installed on 2004 XL883
There are so many threads about this round air cleaner, but I chose this one to post my install experience. First, the install technically should be easy. I bought all the parts listed in my previous post. One major problem I ran into was, the carb support brace holes would not properly line up with the breather. With the right tools I could probably open up the hole on one side of the support brace in order to fit the breather bolt in, but I don't have a vice so I couldn't drill the hole bigger, and I don't have a dremel tool which might also work.
But, I did find out that you can mount this thing with the L brackets that come with the breather kit. The only thing you need to do is add a couple of more washers to each side to make up for the thickness of the now missing carb support bracket. Then the L brackets will bolt right up to the backing plate that comes with the air cleaner kit. It's a nice fit this way so I do believe that if you buy the same parts I did you can omit the carb support brace.
As far as the hose goes, I chose to route that into a small filter. I still have to find a place to bolt it down, but I didn't like the idea of routing the tube under my bike and have the possibility of oil drops on my back tire or the underside of the bike. I haven't decided on a cover yet, but am leaning toward something chrome.
Turbota's Avatar
Turbota Turbota is offline
Turbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really niceTurbota is just really nice
xena .....
Ya did good!
thunderpaw's Avatar
thunderpaw thunderpaw is offline
thunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the rough
Nice job, Xena! I will be joining the round A/C club whenever Ness starts shipping the new Suckers. Are those cable covers on your sparking plug wires or did you replace your wires as well?
Kim
[COLOR="Blue"]I didn't buy a Sportster because I wanted a Harley....I bought a Harley because I wanted a Sportster.[/COLOR]
Similar Threads
Alternate Round AC Solution ? gilx Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 4 16th April 2005 02:07
Round Air Filter Covers for Sportsters? XLFREAK Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 5 1st April 2005 01:09
Drag Specialities 6" Round A/C FiremistSLK Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 2 15th March 2005 21:06
ROUND A/C PROBLEMS!! NO COAST CHOPPER Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 8 14th March 2005 21:53
Round SE AC Install-Update Wizwill Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 5 7th March 2005 14:08
