Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
Figure Machine
Figure Machine
Zippers Performance
CV Performance
Old 1st October 2008
cosper cosper is offline
Sportster/Buell Year: 08
cosper is an unknown quantity at this point
Default front turn signals relocation
i have a 08 nightster with mini-apes. i want to relocate to turn signals to forks. this seems like a pretty simple job, but my only concern is going into the control housing to get the lights out. is this a big deal?
thanks
PaddyOFurniture's Avatar
PaddyOFurniture PaddyOFurniture is offline
Sportster/Buell Model: XL 1250 Custom (was 883)
PaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura aboutPaddyOFurniture has a spectacular aura about
I did mine a while ago. I cut, resoldered, and shrink-tubed them. Worked great looks great (IMHO). Trick is staggering the cuts so that you don't have a great big bulge in the wires when you are done.
Pat
2008 XL Custom 1250
Mustang Wide Solo, V&H Doubleshots, SE AC, Progressive 412s, PCV with autotune
Gilbert, AZ USA
my dealership said that all the would do is zip tye the excess and hide it under the tank
Brad's Avatar
Brad Brad is offline
Senior Master Bolter Oner
Sportster/Buell Model: XL883C
Other Motorcycle Model: Royal Enfield C5 Military
That's what I did. In case I ever go back to my apes.
did you do the relocation yourself?
Brad's Avatar
Yep, But all I did was unbolt the TS, bolt in the MoCo relocation kit and relocate the signals to the forks. Had a bunch of extra wire and tucked it under the tank. Actually, I wrapped the extra wire around my speedo for a year and then the guys bore-assed me into moving it!
What do you mean about going into the control housing? Aren't all of the wires external?
not the wires, but the light is mounted to/into the controls housing(turn signals,horn,on/off).
Brad's Avatar
If it's like my '05, its a simple hex nut to get it out. Look for a hole in the front of the assembly. The TS should be mounted on a bolt that drops out once you loosen the hex nut.
awesome,,,thanks for your help!!!
thumper40063's Avatar
thumper40063 thumper40063 is offline
thumper40063 is on a distinguished roadthumper40063 is on a distinguished roadthumper40063 is on a distinguished roadthumper40063 is on a distinguished road
Default T/s
Thers a little allen-headed set screw right at the front,
loosen that and the whole assem. comes out simple easy.
