Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Zippers Performance
Progressive Suspension
NRHS Performance Long 2
  #611
Old 15th June 2012
ricmachado ricmachado is offline
Sportster/Buell Model: XL 883
ricmachado is an unknown quantity at this point
I got a used 04 883 yesterday.
left the place and started to ride home, everytime I had to stop, the bike was really having a hard time to get going, checked fuel (simtoms looked like no fuel) but was ok.
got to interstate and bike was suffering to pass 60mph, about 15 miles later, I decided to stop and check what was, the bike started to run so crappy that I called the tow back home.
Bike has 25k miles, aftermarket exhaust and SE air kit.
Not sure about any other modification, I sprayed some carb cleaner but didn't work. at end of the day, even idle was hard.
Plugs are black so mixture is too rich.
could this be the sensor?
any ideas?
thanks
Old 15th June 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
thanks
to THE FORUM
It's entirely likely it is the sensor. Mine was very hard to get off idle, but would run ok....until you slowed to idle again. You had to keep the revs up or it would die. The sensor is about $50 and very easy to change.
Stuff: YES
Old 16th June 2012
gotta love internet forums,
new sensor 50.00
10 munites = free
bike is running great, now to fix/upgrade suspension...
let the build begin...
Old 17th June 2012
BWP 5p's Avatar
new sensor 50.00
10 munites = free
Yep......That's about where I went next.....shocks, forks, fork brace, etc!
Old 18th June 2012
Bellropes Bellropes is offline
Sportster/Buell Model: 1200c
Bellropes is an unknown quantity at this point
Yep got the T-shirt and the shorts for this problem, based in the UK, spent a small fortune (for me anyway) and days of work, head scratching, back and forth to dealer for more carb / ignition parts, build, unbuild, rebuild and build again, until my son's car suffered a similar problem and we cleaned his crank sensor to fix his problem; so in desperation I fitted a new crank sensor to the '06 1200C and bingo she ran like a dream......only done 2K miles from new when problem occured....
Old 4th January 2013
offshoreoildude offshoreoildude is offline
Sportster/Buell Model: XL883L
offshoreoildude is an unknown quantity at this point
I replaced mine today. I wish I'd done it before my local mechanic started messing with the carb - all that happens then is you end up with two possible problems.
The symptoms were not quite as bad as others have described - the carb farts when warm were what prompted me to replace it. I now need to go back on the rejetting.
Old 13th February 2013
WhiteDumpTruck WhiteDumpTruck is offline
Sportster/Buell Model: 883
WhiteDumpTruck is an unknown quantity at this point
Is this an issue indicative of a major problem with a bike or more of an "oh well, deal with it maintenance problem"? Pretty lame if you have to replace these sensors all the time.
Looking at an 04 883, pretty much ready to buy but these problems scare me. I can check the codes but they are probably cleared. I don't think I'll be able to ride the bike long enough to see if it's an issue.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
But you don't; I had a rubber mount Sportster for 7 years, and never had to replace one.
Folkie
'The green machine'
Rico 05R's Avatar
Rico 05R Rico 05R is online now
JESTER MAFIA
Sportster/Buell Model: NRHS 1250-R
I replaced one in the eight years I've had mine.
A Member of The Cell
Cool, thanks for the replies! Just trying to get a handle on some things.
