swanny, Mrs Jimi, SnarleyHarley (63), UtahMark, ihjonny (56), fatchuk (55), provision (47), randreb (47), joeyhunter (44), junk runner jr (38), Pegscraper05 (35), cowboy_hamilton1@yahoo.co (34), wi1dwood (34) |
7th September 2006
Posts: 83 Sportster/Buell Model: xlh Sportster/Buell Year: 77
Dual rotor wheels on a single rotor front end?
Can you put a front wheel that came on a bike with duel front brakes on a bike with single front brakes? I need to replace my front wheel but all the good deals are for wheel set up for dual rotors.
Thanks
7th September 2006
Posts: 2,340 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2005 Other Motorcycle Model: Suzuki GSX750ESG Other Motorcycle Year: 1989
I believe the hubs are basically the same but the dual rotor hubs are drilled on both sides.
This supposes that you have the correct axle diameter, etc. You obviously can't run 2 rotors without changing the lower fork sliders since there isn't anywhere to mount the second caliper.
Cheers,
Brett
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
8th September 2006
I don't want to run dual calipers justhe the wheel.
8th September 2006
Posts: 3,302 Sportster/Buell Model: Sportster 883/1250 Stage3 Sportster/Buell Year: 2006 Sportster/Buell Model #2: Buell S1 White Lightning Sportster/Buell Year #2: 1998 Other Motorcycle Model: BMW K1300S Other Motorcycle Year: 2009
You can do that, look at the single disc wheels at the stealer, they are the same wheel with screws filling up the holes where second disc would bolt to.
My Other Toy Goes Mach 25
| Thread Tools |
| Display Modes |
