Get Lowered
The Dart Flyscreen
Old 2nd October 2006
wabiker's Avatar
wabiker wabiker is offline
Sportster/Buell Year: 94
wabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to allwabiker is a name known to all
Default 87 883 w/ Buckhorns
...anybody got a the length for the clutch cable?? Im at work trying to order a replacement online thru JP Cycles so I cant measure mine.
Is it the 63.9 or the 57.5....???
[SIZE="3"][B]IN MEMORIAM:[/B][/SIZE]
[SIZE="2"][COLOR="Red"]VOTE MR JIMI FOR HOTTEST MEMBER...!!![/COLOR][/SIZE]
"Money Wont Buy Happiness, But it Sure would make Misery More Bearable"
But, Its Ok...cuz *I have a Disorder.*
.....Nemo Me Impune Lacessit
'94 Xlh 883 converted to S&S Hot Set-up 1200 kit, 9.2 to 1 comp, Andrews N6 cams, adjustable P-rods,Super E, Cycle Shack M's w/Gronk Baffle Mod, S&S Heads, Thunder Jet, Sifton Bombsight, SE Ign, Progressive 4800-Rear, White Bros Lowering Kit-Front
:pgrflag:
SportsterBart's Avatar
SportsterBart SportsterBart is offline
Sportster/Buell Year: 96
Other Motorcycle Model: Suzuki DR 650
Other Motorcycle Year: 94
SportsterBart has disabled reputation
I just measured mine at just over 55''. Hope that helps.
EDIT: That is just the length of the outer sheath, not the overall length of the internal cable.
Bart
Gonna keep my guns and have my fun and call it just the way I see it.
wabiker's Avatar
Thanks Bart... just to confirm.. you do have Buckhorns?
Yup.
You might want to ask them how they measure their cables, just to be sure.
EDIT: I just checked the J&P catalog, they measure overall length, so the 63.9 might be the right one. I'm not sure tho.
Bart
wabiker's Avatar
Yea... I will... thanks again Bart.
NP
Bart
