The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 1
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Drivetrain > Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive
Lickscycles
Fix My Hog
Dead Creek Cycles
Speedway Instruments
Sky Smith Insurance
Old 3rd October 2006
billyboyblue3's Avatar
billyboyblue3 billyboyblue3 is offline
billyboyblue3 has disabled reputation
Question Primary Chain Replacement
It's that time, I've adjusted the Primary to it's peak. I actually split my adjuster in half while riding. Man, I never want to hear a noise like that coming out of my bike ever again. I guess there was so much vertical force across the thing that it just couldn't take it, especially since I was hot roddin it.
I've heard it is best practice to change the sprockets when changing the drive chain. Is it also necessary to do so when changing the primary chain?
Thanks!
- Billy
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
cantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to behold
Thanks!
- Billy
Take a look at'em and decide then...
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
jamman's Avatar
jamman jamman is offline
Other Motorcycle Model: A Hawg
Other Motorcycle Year: 06
jamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the roughjamman is a jewel in the rough
yes. and what cantolina said...
Cool, I think I'm going to try to get away with not changing them.
I'll give it another look over and make sure there's no excessive wear on the teeth.
Thanks!
cantolina's Avatar
Thanks!
That's exactly the thing....
Don't throw money at a perceived problem "just because"...
I'm sure they're not that expensive, tho.....and it can't hurt....
When you pull the primary case, do whatever is needed, so you don't have to do it again......
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura about
very rare to ever need to replace engine sprockets.... even rarer to have to replace clutch baskets due to sprocket wear... in fact i can't recall ever doin one..
You'll usually go thru a few chains first..
