swanny, Mrs Jimi, SnarleyHarley (63), UtahMark, ihjonny (56), fatchuk (55), provision (47), randreb (47), joeyhunter (44), junk runner jr (38), Pegscraper05 (35), cowboy_hamilton1@yahoo.co (34), wi1dwood (34) |
28th December 2008
Posts: 144 Sportster/Buell Model: XLH883 Sportster/Buell Year: 1998
Has anyone wired this type of passing lights up?
http://sandiego.craigslist.org/nsd/mcy/969781923.html
They don't have instructions and the wires are bare at the ends, so no wiring harness plug-ins. I'm a little weak on the electrical stuff. Anyone have any experience or should I just wait it out for a full kit?
28th December 2008
Posts: 1,022 Sportster/Buell Model: 883/1200 Sportster/Buell Year: 88
Should be a simple install, decide if you want them on the high, low or their own switch. Check your manual for the wire colors for high or low beam and splice them in, or run a new switched hot lead into the headlight bucket.
28th December 2008
Posts: 9,992 Sportster/Buell Model: Gone... Sportster/Buell Year: 2008 Other Motorcycle Model: The Beast (M109R) Other Motorcycle Year: 2006
I ran mine off the low beam power line and put in a separate switch. That way I could run them with or without the low beam and they would not come on with the high beams...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
29th December 2008
That sounds simple enough. As long as I don't hit any snags- knock on wood- the biggest obstacle will be clean wiring!
| Thread Tools |
| Display Modes |
