The Sportster and Buell Motorcycle Forum Sportster Specialty
Figure Machine
Marks Moto Gear
Biltwell
Zippers Performance
Old 14th October 2006
chopperhamp chopperhamp is offline
Sportster/Buell Year: 1973
chopperhamp has disabled reputation
Default leaking primary
i have a 1973 ironhead and where the bolt screws into the hole on the primary is cracked nad no longer able to seal. I have thought about welding it and taping it but am not sure. if you know how to fix this problem let me know. thanks bros ok its the bottom right hole on primary itself it was molded in the primary itself and has broken off thanks yall
Which bolt/hole? Is it the oil drain? Is it in the cover or the case?
Matt Matt is offline
Riding with Angels
Sportster/Buell Year: 1968
Matt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the rough
Welcome! Mick is correct, more specific information is necessary. Matt
S1Eric S1Eric is offline
Sportster/Buell Model: 97S1 97S1 06rigid 79iron
Sportster/Buell Year: many
S1Eric has disabled reputation
Yep some more info would help.
Leaky holes are never good.
OK
I`ll be quiet now.
That was a weak attempt at humor.
S1Eric
stoney's Avatar
stoney stoney is offline
Sportster/Buell Year: 1965
Other Motorcycle Model: Heritage Classic
Other Motorcycle Year: 06
stoney has disabled reputation
I have the same problem with my 65. Mine is not a bolt hole though, it is an "indent" on the top side of the cover,about in the center. It was split about 1/2" long, very narrow width. It was literally augering oil out. I hit it with a very small wire wheel and soldered it up. I would have JB'd it but I was out. I was afraid to wire weld it because of the thickness. So far ok.
