The Sportster and Buell Motorcycle Forum GL Sporster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Frame Mount EVO Sportster Talk (1986-2003 models)
Zippers Performance
Marks Moto Gear
NRHS Performance Long 2
Figure Machine
Old 11th January 2009
07XL1200c's Avatar
07XL1200c 07XL1200c is offline
Epic Eric
07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future07XL1200c has a brilliant future
Default motor swap
My gf just got a 87 sporty, it needs a full motor rebuild, complete rewireing, new tins, basicaly a complete rebuild. Here's my question, will a 2000 or newer motor fit in an 87 frame. im wanting to use an 883 for now till she learns to ride then i will make it run better for her. thanks.
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I'm not sure. It won't fit in a 1988 frame because of the location of the jiffy stand. On 88 models the stand was near the front motor mount. In 89 they moved the stand closer to the middle of the primary. I don't think there's a problem with 89 and later frames, but I can't remember 87 frames.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1972
Other Motorcycle Model: XLH-883D
Other Motorcycle Year: 1988
decman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud ofdecman has much to be proud of
There is a couple of small differences in the jiffy stand area
and the oil pump area that may need to be looked at. I know
this was talked about in other threads, do some searching and get
the added details you need.
