The Sportster and Buell Motorcycle Forum Foxcreek Leather
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Speedway Instruments
Primordial Cycles
Old 7th November 2006
garbiker's Avatar
garbiker garbiker is offline
Sportster/Buell Model: 883
Sportster/Buell Model #2: old ironhead .
Sportster/Buell Year #2: ???
Other Motorcycle Model: 900 kaw z1
Other Motorcycle Year: 73
garbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the rough
Default starter /gen repairs.
I see lots of you do your own rebuild . So a tip to help.AS most of you do not have a lathe to turn the armature I will tell you how the easy way. First take a drill put it in a vice then the armature in drill the brass end to drill. then get a strip of sand paper (fine) that will just fit the brass end OR a small flat file and turn drill on and polish the end . AFTER clean it good and break a fine hacksaw blade and clean out the groves or cut a new ones not deep but enough so you have a small one to help from a short between them and the brushes will make a good contact.IF you do not clean the groves the brass dust will short enough so the starter will not spin fast or flat spot. THE end has to be shiney no burnt or black spots. AND lots of them will have a ridge where the brush does not fit. THE end has to be flat no ridge. so take the ridge off so you have a smothe end .then reclean and new brushes and you are good to go with new end bushings and a small amount of lube on the ends. This has worked for me on lots of gens and starters. be sure the file lays flat and covers the comp brass end.or the sand paper strip . Good luck hope this will help some one. and has to be cleaned inside good. cu gar
Fork's Avatar
Fork Fork is offline
Sportster/Buell Model: FLHTC
Sportster/Buell Year #2: 1973
Fork has disabled reputation
A very good tip!! Thank You!
