15th November 2006
Posts: 10,085 Sportster/Buell Model: 1998 S= Superior Model Sportster/Buell Year: 1998
turn signals
i picked up an 1200 c 1997 i traded my 883 for it but the turn signals wont cancel got my manual out but dont see anything but a turn signal module all the lights work and the flashers too the signals just dont turn off & how hard is it to replace the high beam indicator light it looks like i have to remove the bars & speedo and tach to get at the wireing to replace the bulb it sounds like i have a bad ground or the signal module is bad ?
Sportsters Rule !
15th November 2006
Posts: 3,435 Sportster/Buell Model: 1200 Custom Sportster/Buell Year: 2006
Courtesy
hopefully someone might be able to help you out on this one...
15th November 2006
Posts: 2,935 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2002
don't know if this may help but my friend who has a sporty was having a problem with his module turning the signals off to soon and he was told to cut a wire coming out of the module that would make the signals stay on until he hit the turn signal switch again. Check the module and maybee see if one of the wires are cut. I know he got that info off of here so maybee whoever gave him that info will see this thread and be able to say which wire it was.
2002 XL1200C (originally)
Stage II Buel XB Heads, Andrews N4 Cams, Mikuni HSR42 Carb, Forcewinder Air Filter with Float bowl vent mod, S&S Roller Rockers, Jim's Powerglide Lifters, Thunderheader Exhaust, Daytona Twin Tech SIngle Fire Ignition, Crankvents.
Max Power=85.47
Max Torque=81.84
Flow Bench Results
15th November 2006
kinda funny i post here and dont seem to get a lot of answers lately ! clarinetcat thanks for the help !
15th November 2006
nope checked all the wires when i switched out the tins & hooked up my tender jr everything looks good i noticed it when i took it for a test ride but still did the trade ! thanks mike !
15th November 2006
Sometimes the people that are on when you first post may not know an answer... especially electrical stuff, which I think is pretty hard to figure out anyways.
Don't get frustrated or take it personally, just have a little patience with the posts.
I hope you can get it worked out!
16th November 2006
Posts: 2,631 Sportster/Buell Model: 94 HP XL1200C sold :( Sportster/Buell Year: 2002 Sportster/Buell Model #2: Yamaha Raider Sportster/Buell Year #2: 2010 Other Motorcycle Model: Yamaha FZ1 Other Motorcycle Year: 2008
Replacing the indicator bulbs on my 1200C is a piece of cake. I'm not real familiar with the 97. Do you have a riser? All my stuff was accessible by taking the riser cover off. I'm not sure just a bad ground would make the canceller not work though.
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
16th November 2006
Posts: 251 Sportster/Buell Model: 883 (1200) Hugger Sportster/Buell Year: 1999 Sportster/Buell Model #2: Springer Softail Sportster/Buell Year #2: 2001 Other Motorcycle Model: Electra-Glide Other Motorcycle Year: 1983
There is a white/green wire that sends a signal from the speedometer to the turn signal module. This tells the module how far the bike has traveled since the turn signal has been turned on, and after a certain distance, it should cancil the turn signal.
16th November 2006
Posts: 374 Sportster/Buell Model: sporster Sportster/Buell Year: 95
some time the module is just screw up & has to be replaced & as for the light it should take about 7 to 10 min to change so if your dealer does it there should be about half hour shop charge & if they are half decent thay should replace the light for free & check the mod before the would replace it
16th November 2006
I Don't get frustrated i just get bummed this is the best group around and i look forward on a daily basis to comming here and finding out all the information i can about sportsters the best bike all around & and the most knolwedge heck with 100000 memembers you would think this is the best site around we are in the same boat as far as bikes go we all want to go faster and modify our bikes to make em our own but we all need to help each other out if i dont know i will ask if you dont know ask and get the proper information ! thats whats this place is all about !
| Thread Tools |
| Display Modes |
