22nd November 2006
Posts: 77 Sportster/Buell Model: xl1200L Sportster/Buell Year: 2006
Rear Turn signal install on an 06
I just finished installing a rear turn signal relocation kit on my '06 1200L. It was with some trepidation that I approached this project, because I found the kit on E-bay with no instructions. I had read some comments about "cutting wires" in order to install the kit. Cutting and rewiring was not a task I wished to under take. However, I did not have that problem. I read through my HD maintenance manual and found sections describing the removal of the OE turnsignals and also how to remove and reinstall the wiring plug for the rear turn signals. First I had to remove the license plate bracket. To my relief, I discovered HD had already provided a hole for the new wires. I ran the new wires, and then removed the brake light lens. Easily accessible were the plugs and wires to the OE turn signals. The manual described how to remove the wires from the plugs and replace them. It indicated that a special tool was required to perform this operation. I used a small flat blade screwdriver and some patience. The new lights were on in 20 minutes. My problem was removing the old lights due to the fact I did not have access to a lift, could not remove the rear wheel and was performing this operation in the parking lot of my apartment complex. I was successful after about an hour with some sweat and choice words.
Next step... saddlebag brackets. does anyone know how to fabricate their own?
My digital camera was dead, so unfortunately I was unable to record my successful operation.
Ride Safe! Sportsters Rule!
"The Oxen are slow....but the Earth is patient..."
2006 XL1200L with Mustang wide vintage solo, Leatherlyke Saddlebags, low sissybar, luggage rack and compact QD windshield hardware with New Lexan by Memphis Shades.
22nd November 2006
Posts: 319 Sportster/Buell Model: xlh Sportster/Buell Year: 1996
I fabb'd my brackets. I made mine out of alluminum. Went through the stock fender mount holes. Then mounted the bags to the alum. bracket. This allows me to remove the bags w/out loosening the fender. Be careful to have enough clearance between the tire & bolts. I ran pan head bolts on the inside to the brackets. [IMG]  [/IMG][IMG]  [/IMG][IMG]  [/IMG]
Work To Ride, Ride To Work!
22nd November 2006
Brass Nut
Posts: 30,439 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
If anyone wants to do this, don't buy the tool (Snap-On TT600-3)! Not only isn't it necessary for the turnsignal plugs, it's unusable because it's too thick. It might be usable for some of the bigger plugs on the bike. I just used the smallest screwdriver out of a set of jewellers (instrument pattern) screwdrivers. Probably a thick needle would do just as well.
Folkie
'The green machine'
23rd November 2006
hey those are greating looking brackets!!...you must have access to a cnc machine. Thanks for the tip!
25th November 2006
Not a CNC, bolted both together, roughed out on band saw and belt sander, then free hand on mill with a rotary table. If I only had a CNC.... This winter I plan on my own homemade fwd controls. With a budget like mine, the floors the limit. [IMG]  [/IMG]
2nd December 2006
Cool, even more ideas floating around now in my noggin'.
Ride safe!
| Thread Tools |
| Display Modes |
