The Sportster and Buell Motorcycle Forum Figure Machine
famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
Don's Cyclewear
Old 28th November 2006
tuck75sporty's Avatar
tuck75sporty tuck75sporty is offline
Sportster/Buell Model: sportster xlh
tuck75sporty is an unknown quantity at this point
Default what kind of paint
whats up guys?? im wanting to paint my primary and cam covers black on my 75 ironhead as well as the frame. i was just gonna rattle can it with rustoleum high heat paint which is a flat black(thats the color im going for) but i have been told that i dont need to use the heat paint and just get some good enamel. and since its bare aluminum...should i prime it or just stracth it up real good?? so any opinions and what would be best to use are appreciated??
Sportster/Buell Year: 1972
Might want to post a paint manufacturer website or something like that. Powder coat would be ideal for covers. I even think there are do at home setups you can buy. I guess you would have to bake it in the kitchen oven though. THAT would probably piss the OL off..........
When painting the cylinders and heads you need very high heat paint - 1200 to 1500 `F; ordinary engine paint good to about 600 `F will not do.
The covers do not get that hot. However i do not know what would be the best choice.
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
cantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to behold
Depends on how far you want to go....especially with the frame...
For the covers, the high-heat rattle can stuff is fine...
For the frame, I usually just scotch-brite the parts I want to paint, then final wash them and spray or small brush....
The frame can be a PITA to COMPLETELY paint if its not been torn down (engine out)
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
Old 29th November 2006
zman69's Avatar
zman69 zman69 is offline
Sportster/Buell Model: 883R
Sportster/Buell Year #2: 1972
zman69 will become famous soon enoughzman69 will become famous soon enoughzman69 will become famous soon enoughzman69 will become famous soon enoughzman69 will become famous soon enoughzman69 will become famous soon enough
painted my covers on my 72. You can see the primary in this pic. I just used normal rattle can high heat paint. Scuff, prime, paint.
"WFO From The Get Go"
1972 1000 XLCH
2003 883R
thescreenman's Avatar
thescreenman thescreenman is offline
Sportster/Buell Model: 1973 early xlh
thescreenman is on a distinguished roadthescreenman is on a distinguished road
I second powder coat,If you have a oven you can use,the cost will be made back on other parts and will hold up better.You can rattle can it but you will be doing it often.The pj-1 epoxy high temp holds good and is a harder paint as far as scratching goes and comes in a rattle can.
Old 30th November 2006
dandzivi's Avatar
dandzivi dandzivi is offline
Sportster/Buell Model: XL Streetracker
Sportster/Buell Year: 1979
Sportster/Buell Model #2: S3
Sportster/Buell Year #2: 1995
Other Motorcycle Model: H-D 350 ERS Replica
Other Motorcycle Year: 1971
dandzivi has disabled reputation
Make that three for powdercoating. If you are going to keep the bike for a while, it is the only way to go. It ain't cheap, but you only have to do it once! I've PC'd the frames on the last 4 bikes I built and all the side covers and rocker boxes on the last two. No regrets (except the cost)
onadraw's Avatar
onadraw onadraw is offline
onadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enough
dandzivi, curious, what did it cost to powdercoat the frame and covers from one bike?
Old 1st December 2006
jessechop jessechop is offline
jessechop has disabled reputation
Rustoleum takes forever to dry, I pefer krylon! I have had a frame powdercoated and in all honesty didnt like it and will never have another coated
theoldog's Avatar
theoldog theoldog is offline
theoldog has disabled reputation
Around here (Indiana) powdercoating a frame runs around 100 bux. I had my FXR frame powdercoated last year for $75.00, but I had to have it blasted, another $30.00. I have had quite a few parts PC'd over the last few years, and it really is some good stuff.
