Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > EFI Sportster Motorcycle Talk (2007 and up)
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Speedway Instruments
Biltwell
Progressive Suspension
Old 1st December 2006
rharrison356's Avatar
rharrison356 rharrison356 is offline
Sportster/Buell Model: XL50 #870
rharrison356 is an unknown quantity at this point
Default Anyone changing to 7000 rev limit?
Has anyone changed valve springs in order to increase rev limit to 7000 rpm? How did you overcome the ECMs rev limiter? Any other modifications?
07 XL-50 #870 Stage 1
06 VRSCR "Hyper-fast Touring"
Kansas City Missouri
λεγει αυτω ο ιησους εγω ειμι η οδος και η αληθεια και η ζωη ουδεις ερχεται προς τον πατερα ει μη δι εμου John 14:6
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
My ignition has adjustable rev limit, but I hate to rev my motor past 6500 and even that makes me cringe. It's the thought of the piston speed that worrys me. How often do you want to rebuild your motor?
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
I don't think you need to change the valve springs to rev the engine to 7K rpm. I think the stock valve train can safetly rev to 7K rpm. If you look at the SE catalog they have a chart where they put in SE E cams and increased the rev limit to 7K rpm without changing the valve springs.
2005 XL1200C
Those who trade liberty for security have neither.
lagerdrinker lagerdrinker is offline
lagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the roughlagerdrinker is a jewel in the rough
my engine isnt making any significant power over 4000 rpms. i shift when needle hits around 5800rpms to keep it off the limiter
Swankster's Avatar
Swankster Swankster is offline
Master Bike Builder
Sportster/Buell Model: Nill
Swankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the rough
Damn! lager are you srerious? Mine is just seriously kickin in around that range . Serious!
Swankster
"Stop Global Whining"
"Life, Liberty and the Pursuit of Anyone Who Threatens It"
"A Dead Enemy Is A Peaceful Enemy - Blessed Be The Peacemakers"
Still BIKELESS & hating Life!
Swankster
yeah, heres my dyno sheet. from around 4-6k rpms i gain 3 hp. still using 883 heads and 497 cams. need headwork done to get more
roadster roadster is offline
Sportster/Buell Model: SEVERAL
roadster has disabled reputation
7K is a bit silly with these motors. Maybe keep some spare cases on hand....
You'd be better off winding a stock Chevy 350 to 8K
cadiero's Avatar
cadiero cadiero is offline
Other Motorcycle Model: BMW R1200RT
cadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enoughcadiero will become famous soon enough
The XB's have a 7K rev limit stock. I would think the motor can handle it.
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Bike Builder
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to all
Don't forget the XB's are a different animal. You guys can correct me if I'm wrong but I think the Buell's have a lighter flywheel asembly and the stock valve trains are different that a Sportster's. So going to 7k with one is easier.
I think that if H-D thought a stock Sportster could go to 7k they would of allowed it from the factory. Performance bike selling point, yes? I know that the SE ignition lets the motor rev but I'm sure they felt that the usage of that unit would be for modified motors not stockers.
Plus I have to agree with Lager why would you want to rev a stock motor to 7k it's not like it's going to make any more power. If you are racing you try and shift within the power band not outside of it.
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
seajay's Avatar
seajay seajay is offline
Bike Builder
Sportster/Buell Year: 04
seajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really nice
My '04 stock ignition rev limiter was 6k.
04 76"C NRHS #2 CP 10.5:1 .575 cams TP rockers TC88A HSR-42 S&Sac LSR 2-1 Can you say--- screamer?
