2nd December 2006
Posts: 12,646 Sportster/Buell Model: xl1218rr turbo Sportster/Buell Year: 1993
Finally learned something useful at a Harley Boutique
I was at the Harley shop buying the nuts and bolts I need to reassemble the front end and they did not have the right size bolts(tooooo long). Told him I would cut them and he told me to run a nut down the bolt first so when I removed it it would clean up the cut threads nicely. Sounded smart to me so I will try it.
I also learned it is fun to go there because the local dealer always hires three or four babes to work up front and flirt with us older guys. That girl was toooooooooooooo hot for my perverted old mind.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
2nd December 2006
Posts: 2,511 Sportster/Buell Model: 883c Sportster/Buell Year: 2004 Sportster/Buell Model #2: Flyrite Rigid completed? Sportster/Buell Year #2: 2003
You are lucky to actually have someone at HD to know a little something.
He is right I have done that many times.
2nd December 2006
Posts: 310 Sportster/Buell Model: sportster Sportster/Buell Year: 2004 Sportster/Buell Model #2: 1200 custom
yep ,me too, thats how u do it.
2nd December 2006
Posts: 535 Sportster/Buell Model: XL1200 custom Sportster/Buell Year: 2006
Up here to. Hot babes up front, screwing in the back!!(PARTS COUNTER)
I'd rather be in my boat with a drink on the rocks
Than in the drink with my boat on the rocks:doh
[url]http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=5013[/url]
I don't just ride a Harley.I pilot a SPORTSTER!!!
2nd December 2006
Posts: 311 Sportster/Buell Model: sportster 1200 Sportster/Buell Year: 2004
Ralph when you cut your bolt with the nut on it, clean up and level the cut end with a file so that when the nut comes off the bolt there will not be a wire edge to the bolt and the nut will be easier to start the thread.
2nd December 2006
I always clean them up with a dremel stone. Just thought it was a great idea.
3rd December 2006
Brass Nut
Posts: 30,446 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
Yes , me too; I've always done that. If you're cutting really small screws, putting on two nuts locked together, if there's room, gives you something to hold the screw steady by as well.
Folkie
'The green machine'
3rd December 2006
Riding with Angels
Posts: 1,963 Sportster/Buell Model: XLCH Sportster/Buell Year: 1968
A thread chaser set is not too expensive and is a good thing to have around. Works better than a nut. Cutting a slot in a bolt and cleaning up with a nut as described will make a tool to clean female threads in alloy if you don't have a chaser. You can do the same with a sparkplug but be careful! Matt
3rd December 2006
Brass Nut
True, but it's still useful to have a nut on there when you make the cut. Removing the nut opens up the thread where cutting the screw has closed it off.
3rd December 2006
Posts: 257 Sportster/Buell Model: 1200 Roadster Sportster/Buell Year: 2006
Ralph, Next time you go in there, I think those gals might love to pose with you for a group picture for the greatest forum around.
"Nobody made a greater mistake than he who did nothing because he could only do a little."
- Edmond Burke
[URL="http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=4676"]View My Gallery[/URL]
[FONT="Palatino Linotype"]2006 Sportster Roadster (yellow pearl), Thunderheader, Forcewinder A/C, 48 slow jet w/2.5 turns out on the mix screw, 200 main jet, 1 brass shim under the needle, TwinTec tc88a igniton module and coil, Krankvents, ISO grips, and Progressive 412 shocks and fork springs, and a few other doo-dads.[/FONT]
| Thread Tools |
| Display Modes |
