17th March 2005
Posts: 1,488 Sportster/Buell Model: 1200 XLC Sportster/Buell Year: 2000 Sportster/Buell Model #2: Dyna Low Rider Sportster/Buell Year #2: 2004
Changing Tires/Wheels
Any tips or advice for changing front and rear tires? I'll be R and R ing the wheels but taking them to a shop to swap the tires.
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
17th March 2005
Posts: 1,576 Sportster/Buell Model: Custom 1200 Sportster/Buell Year: 2004
There are a number of "how to" websites with pictures!
This may be the best!
Please! No charge!
Billy
1. http://www.clarity.net/~adam/tire-changing.html
Oh Yeah!
My motorbike is better than your motorbike!
My dad can beat up you dad!
Yo momma!
17th March 2005
Sorry, that's more about changing the tires, which I'm sending them out for. I'm looking for info on removing the wheel from the bike and reinstalling it.
17th March 2005
Yea, but you guys know ALL the tricks.
17th March 2005
Assistant Administrator
Posts: 9,981 Sportster/Buell Model: 1212 conversion/497 cams Sportster/Buell Year: 2004
Do the "follow the manual" trick and you'll be fine. Torque everything to spec since the wheel is a critical point.
One tip I can offer is, loosen the axle nut but don't remove it until you take note of the order or your washers and spacers. That was the only thing I had an issue with when re mounting the front wheel and my manual was not very specific about it.
19th March 2005
Xena - Thanks...That's what I meant. Here's another question for you. The manual says to remove the brake caliper and let it hang loose before you remove the wheel. I'm wondering why I can't just pull the wheel straight out and leave the caliper alone? The disk (which is what I'm replacing) should just slide out, no?
19th March 2005
Posts: 139 Sportster/Buell Model: 1200 XL Custom Sportster/Buell Year: 1996
Ya.. you can... but try sliding that disk back between the pads when reinstalling the wheel. Allot less headache to remove the caliper and reinstall it after the wheel is back on. Less chance of damaging something also.
19th March 2005
Thanks, Mickes
19th March 2005
Done...Had to leave the caliper on because I don't have those friggin wrenches to take the caliper mounting bolts off. It wasn't bad at all. I'm gonna change those bolts out to something more reasonable ASAP.
24th March 2005
Sham, the Caliper bolts use a 12pt socket (think it was metric if I recall correctly) I forget the size, 10mm maybe? Manual should say.
| Thread Tools |
| Display Modes |
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Changing out a rear fender, how difficult?
E00i3 |
Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders |
12 |
5th March 2006 22:09 |
Changing Grips
Stumble |
Sportster Motorcycle Accessories |
5 |
14th February 2005 21:21 |
changing rear shocks...
harleymanjay04 |
Sportster Motorcycle General Discussion and Problems |
27 |
14th January 2005 02:04 |
Changing covers
dcinpa |
4 |
13th January 2005 19:42 |
Brake pad, changing.
Chuck |
17 |
13th January 2005 12:53 |
