The Sportster and Buell Motorcycle Forum Figure Machine
Dead Creek Cycles
Sportster Specialty
Sportster Specialty
Licks Holiday
Don's Cyclewear
Old 22nd December 2006
Massdog05's Avatar
Massdog05 Massdog05 is offline
Massdog05 has disabled reputation
Default best place to order ANDREWS N8?
What's the best place (cheap but reliable) to get Andrews N8 cams for a 99xl? Found on ebay, but going through a store (real or online) would make me a little more comfortable.
1999 XL1200S,
Performance: 05 1200C Heads Dual-Plugged, SE 7500RPM Ignition Module, Andrews N8's, SE A/C & High-Flow Filter, Port-Matched Intake Manifold, Homemade Breather Kit, Thunderheader Exhaust, High Flow Petcock,
Aesthetic: black motor, wide-glide 39mm triple trees, braided stainless lines, 1200L handlebars w/ internal wiring, Corbin Dual-Tour with driver backrest, sissy bar/pad, HD bullet turn signals, bottom mount headlight, HD teardrop mirrors, mid controls with highway pegs, o-ring pegs, turn signal relocation bar, Kuryakyn R.B.T. module, homemade lay down license plate, high output horn & 1200C cover, l-to-r derby cover,
snowman's Avatar
snowman snowman is offline
snowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to behold
Talk to the guys at NRHS. They are a forum sponsor and great guys to work with:
http://www.nrhsperformance.com/
Good luck..........
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Massdog05's Avatar
called but they are out of stock and will take too long to ship.
biknut's Avatar
biknut biknut is online now
Sportster/Buell Year: 1988
I saved a couple hundred dollars on a Andrews transmission from this shop.
Service was pretty good too.
http://www.jimscycleshop.com/index.html
Old 23rd December 2006
Gone Gone is offline
I've bought a lot of parts off ebay and have found sellers to be reliable; check their feedback. I don't do "cash only" or "no PayPay" and have received excellent service, including refunds to PayPal.
Jim's Cycle Shop is just outside Waco; decent guy and his son own the business. Harley's only! and would be a good choice if the forum vendors can't help soon enough.
See my recommendation under stealers, dealers, etc..
cbmotorsports's Avatar
cbmotorsports cbmotorsports is offline
Sportster/Buell Model: 883c to 1250
cbmotorsports is an unknown quantity at this point
what about a local bike mech. that is a dealer? Or you could go to J&P cycles.com $289 I think.
Massdog05's Avatar
one on ebay is selling for 230. feedback is near perfect at 30,000. but no refunds if anything is wrong. has anyone installed the n8's (#298185) in a '99 xl 1200? were there any problems with fit or was it a simple install??
rottenralph's Avatar
rottenralph rottenralph is online now
rottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant future
I have them on my 93. 10 years now and running strong. Good cam for compression. I will be installing 10.5 to 1 pisotns this year with jet heads. Should be a screamer. It was hot as hell in the dyno room when they ran my bike so the numbers were lower than they would be in normal conditions. 103 degrees in the room with no air.. I think the s model had higher compression if my memory serves me right. The torque curve comes up fast and holds in the same are for 2500 rpm before it starts to drop.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
Old 3rd January 2007
NickNasty's Avatar
NickNasty NickNasty is offline
NickNasty is on a distinguished roadNickNasty is on a distinguished road
Default Andrews N8 Cams
I bought my N4's from Jireh, 1-(877)681-0448 or jirehcycles.com, part # 114-166, $219.95, same price as I paid for the N4's...S&H over $75 FREE!!! I bought a lot of parts from them for the 883/1200 conversion. Best prices I found....Nick
Old 4th January 2007
Massdog05's Avatar
thanks nick! i had already ordered them from dennis kirk for 259 which i thought i was satisfied with. found them at jireh's for 219, so dennis kirk is matching the price. $40 back for me to spend on my baby! (the bike)
