Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
Licks Holiday
Progressive Suspension
NRHS Performance Long 2
Biltwell
Old 4th January 2007
crharvel's Avatar
crharvel crharvel is offline
crharvel has disabled reputation
Thumbs up How to prevent terminal corrosion?
With all the problems that can be caused by deteriorating connections at the battery, what have folks found to be the best at slowing/preventing corrosion?
[FONT=Arial Narrow][COLOR=black][URL="http://xlforum.net/photopost/showgallery.php/ppuser/13121/cat/500"][COLOR=blue][B]Yes.... it looks just like yours...and the other 900 in the gallery[/B][/COLOR].[/URL] [/COLOR][/FONT]
[FONT=Arial Narrow][/FONT]
[FONT=Arial Narrow]This is where I am supposed to make a witty comment about "paying taxes" right?[/FONT]
kerby's Avatar
kerby kerby is offline
Sportster/Buell Model: xl
kerby is an unknown quantity at this point
vaseline works
sprtrjl sprtrjl is offline
Other Motorcycle Model: Heritage Softail Classic
sprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nice
Di-electric grease
klown klown is offline
Banned
klown is on a distinguished roadklown is on a distinguished roadklown is on a distinguished roadklown is on a distinguished road
You can buy this stuff in a can at autozone that you can spray on your battery terminals to pretect them. I've used it and it works good.
Old 9th January 2007
Drew1200c's Avatar
Drew1200c Drew1200c is online now
Sportster/Buell Model: 1200c
Drew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enough
what about the fuse box, I noticed some corrosion starting already. Has anyone tried or knows of a spray I could use if I pull out all the fuses.
Old 15th January 2007
Drew1200c's Avatar
I found some spray contact cleaner at home depo, pulled all my fuses sprayed the fusebox with the contact cleaner. used 500grit sandpaper on the fuses, a little di-eletric grease and put it all back together. I hate the way that stupid battery cover snaps on, fell down a few times while driving so I removed one of the mounts and now zip-tie the sucker, I found some reuseable zipties while I was buying the contact cleaner.
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
All my motor vehicle owning life I have just used WD40 or similar products and have NEVER have one spot of corrosion on battery terminals.
Give 'em a quick spray 2 or 3 times a year and they're good.
