Dead Creek Cycles
Flying Piston
NRHS Performance Long 2
Lickscycles
Old 28th March 2009
joemoto's Avatar
joemoto joemoto is offline
Sportster/Buell Year: 1976
joemoto is an unknown quantity at this point
Default 76 ironhead oil leak and chain oiler
Hey guysI got mike bike running just have a few problems the oil line that comes from the bottom of the oil bag is leaking can i change that with the engine in the bike??do i have to drop the exhaust and the foot peg??? and how do i block off the chain oiler??
Old 28th March 2009
sturgmachinist's Avatar
sturgmachinist sturgmachinist is offline
Sportster/Buell Model: xl 1000
Sportster/Buell Year: 74
Other Motorcycle Model: Honda RatWing
Other Motorcycle Year: 79
sturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of light
My 74's chain oiler had an adjustment bolt that I just closed off....I guess it was an adjustment bolt...I closed it and it and oil stopped coming out
"we, outlaws on God's property,
Fling out imagination beyond the skies,
Wishing a tangible good from the unknown."
74 Custom Rigid XL,
"stuff"
Some dirty chrome, a little duct tape and lots of rust
One headlight, one tail light, one brake, and lot's of balls!
Old 29th March 2009
supr2nr's Avatar
supr2nr supr2nr is offline
supr2nr is on a distinguished roadsupr2nr is on a distinguished road
+1 on that. I did the same on mine. No reason for it. I just use wd-40 on my chain.
And the oil line on the bottom of the oil tank is the feed line, it runs to the oil pump and out of all three oil lines that one is the absolute easiest to change. No need to remove anything to change it. You should be able to squirm it around enough to get one in without having to remove anything.
- Randy
Old 19th May 2009
joemoto's Avatar
found it but i also found the over flow the smallest oil line of the cap had a split in it causeing some puddles when i shut her off where does that oil line go? is it hard to get at?
Old 19th May 2009
1976 XL's Avatar
1976 XL 1976 XL is offline
Sportster/Buell Model: Sportster XL
Other Motorcycle Model: Springer Softtail
Other Motorcycle Year: 89'
1976 XL is on a distinguished road1976 XL is on a distinguished road
You Dont Have An Over Flow, You Have A Feed Line, Vent Line, And Return Line. All Should Be Working Well With Free Flow. My Chain Oiler Is Blocked Off, No Need For It Today With Clinging Chain Lubes, They Usually Have Paraffin In Them That Will Stay On Even At Higher Speeds.
Old 19th May 2009
joemoto's Avatar
yeah the vent line was split I think this is where the oil was coming from is it hard to get at the vent line?? it disappears behind the case??
Old 19th May 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Hopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to all
The vent line connects to a pipe fitting in back of the cam gear casing, behind the rear cylinder, down to the right, in behind the timing cover. Can be a biatch to get to but you dont need to pull the engine or cam cover. Depending on what model bike you got, you might have to move the electric starter, exhaust pipe or oil tank. No big deal.
You should replace all your oil lines.
If one or two have split, the hoses are old and the others will be ready to let go any time, which could trash your engine or even cause a crash if the oil ends up on the back tyre.
Don't use fuel hose. It will go hard and crack prematurely.
Use hose rated for hot oil.
Automotive auto transmission cooler hose is even better again.
Old 19th May 2009
joemoto's Avatar
I have had the starter and oil bag off and did not see it it goes back where the chain oiler feed line is?? can you get tranny line in 1/4 inch? that is the size of the vent line.
Old 19th May 2009
Important note on replacing oil lines:
The parts book specifies both the ID and the OD of the lines. If you buy certain automotive lines they will have a larger OD and will be very difficult to run in the limited space, and they may kink easily.
Correct sizes ...
oil lines: 3/8" ID, 5/8" OD
vent line: 1/4" ID, 1/2" OD
Old 19th May 2009
joemoto's Avatar
my bike is a 1976 xlh1000 if i take off the sprocket cover will i see the vent line?
