Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
NRHS Performance Long 2
CV Performance
Primordial Cycles
Old 11th March 2007
Massdog05's Avatar
Massdog05 Massdog05 is offline
Massdog05 has disabled reputation
Default adjust idle
how do i adjust the idle RPM's? it's been rejetted and the idle is sitting at 750-800 rpms and though it will stay running it seems like it wants to die if i don't sit there and blip the throttle. Is there some kind of screw that i can get to to raise the idle to maybe 900 or 1000 rpm's?? I searched my service manual but couldn't find anything.
1999 XL1200S,
Performance: 05 1200C Heads Dual-Plugged, SE 7500RPM Ignition Module, Andrews N8's, SE A/C & High-Flow Filter, Port-Matched Intake Manifold, Homemade Breather Kit, Thunderheader Exhaust, High Flow Petcock,
Aesthetic: black motor, wide-glide 39mm triple trees, braided stainless lines, 1200L handlebars w/ internal wiring, Corbin Dual-Tour with driver backrest, sissy bar/pad, HD bullet turn signals, bottom mount headlight, HD teardrop mirrors, mid controls with highway pegs, o-ring pegs, turn signal relocation bar, Kuryakyn R.B.T. module, homemade lay down license plate, high output horn & 1200C cover, l-to-r derby cover,
Old 11th March 2007
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
The idle speed adjustment screw is on the front of the carb (ie: the side towards the front of the bike); it has a spring beneath the screw head.
Folkie
'The green machine'
Old 12th March 2007
Massdog05's Avatar
thanks! that's what i needed to know!
