12th March 2007
Posts: 24,004 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
1986 Sportster Carb What is this?
I have a 1986 XL Harley Keihin type carb that i bought on eBay. Going to use it on my 1980. It has the VOES port that i want, and a better fast idle linkage which i also want.
See the attached pic. What is this extra port? The carb arrived with this plugged; i removed the plug for the pic.
This is a slightly updated version of the original Keihin carb that is on my 1980. It arrived with a 155 main and a 52 slow which presumably was correct for a 1986 Evo.
Any ideas about starting jetting for this carb on a 1980? The jetting on the original carb was 160/68 which i changed to 165/68. I have a feeling this carb may need the smaller slow as it has a more sophisticated circuit; but i do not know; so i am thinking of starting with 165/52.
12th March 2007
Senior Bike Builder
Posts: 1,945 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: XLC Sportster/Buell Year #2: 1958 Other Motorcycle Model: XLRTT Other Motorcycle Year: 1966
Hi Mick,
Dunno, could be extra venting to air cleaner or other version of vaccum switch...
Anyway, in my opinion, the Keihin only falls into 2 categories: the pre-1979 which are designed and OK for iron heads, the post-1980 which only deserve to be kept for parts like floats, gaskets etc...the rest, bodies, jets etc can be put without hesitation in the garbage can as they were designed with EPA regs in mind, not performance, hence they have wrong venturis and don't flow half as well as the earlier types...
I speak from experience, probably have 20 of the buggers on my shelves, the only decent ones are easy to identify: all pre-79 are single cable operation AND adjustable iddle mixture screws, not hidden ones under blanks...
I usually run my earlier ones with 75 to 100 iddle jet, 160 to 175 main jets.
All the best from Patrick
Flat Head Forever...
12th March 2007
Posts: 2,493 Other Motorcycle Model: A Hawg Other Motorcycle Year: 06
Vacumm for the petcock
12th March 2007
Posts: 533 Sportster/Buell Model: XLCH Stroker Chop Sportster/Buell Year: 1974 Sportster/Buell Model #2: XLH Bobber Sportster/Buell Year #2: 1977 Other Motorcycle Model: XLH Project ????? Other Motorcycle Year: 1980
I agree, the pre-1979 Keihin's are a good, reliable, easy to tune carb, for daily riding, & I talked on this in another thread, you can get some performance out of them.
Red
12th March 2007
Posts: 6,029 Sportster/Buell Model: XLX-61 Sportster/Buell Year: 1983 Other Motorcycle Model: Honda CL350 Other Motorcycle Year: 1969
I answered this question on the "other" thread, so here's a repeat:
The circled port is where the VOES hose on an '83 connects. The '84 and later butterfly carbs added another port at the intake manifold connection flange. They capped the original one, and attached the VOES hose to the new port. I suspect that the capped port was for the California models evap cannister hose.
On a stock motor with stock air cleaner and pipes/mufflers, a 160/52 was standard on the last ironheads. Starting out with a 165/52 is probably fine, too.
I'll add that I don't think it's for a vacuum petcock, as these came along much later. Also, there's nothing wrong with the later Kehin butterfly carbs. A few simple mods and the EPA crap is history.
12th March 2007
Master Bike Builder
Posts: 2,045 Sportster/Buell Model: 883-1380cc hot rod Sportster/Buell Year: 87 Sportster/Buell Model #2: wife's 883-1200 Sportster/Buell Year #2: 87
Have the same carb on wife's early 87. That tube has a rubber cover on it. Very easy carb to tune. Works very good on wife's bike.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
12th March 2007
Posts: 1,691 Sportster/Buell Model: XLH Sportster/Buell Year: 1980 Other Motorcycle Model: FXDBi Street Bob Other Motorcycle Year: 2007
I dont really know either Mick but I am going to swap my keihin with the S&S Super B and get rid of the Jap crap.
Ain't No Head Like an Ironhead !!!!!!!
Chris
http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=13392 My Gallery
http://outlaws-iguana-ranch.com Outlaws Website
http://i258.photobucket.com/albums/hh266/OutlawTexan67/My%20Ironhead/Gifs/BigRotatingSkull.gif "Ironhead Mafia" European Chapter
12th March 2007
Better throw your front forks and rear shocks in the trash, too, if you still have the originals. Made in Japan.
12th March 2007
Already done about 3 months ago
12th March 2007
Senior Bike Builder
ted
Not so easy in my view, what do you do then with the awful cast in post 79 venturi that's absolutly useless for high revs/engine response?
It's "built in" untunability...
Patrick
| Thread Tools |
| Display Modes |
