9th May 2009
Posts: 1,436 Sportster/Buell Model: 1988 4 speed XL 1424cc Sportster/Buell Year: 88 Other Motorcycle Model: 2003 Road Glide 95" stg 2
Solvent?
I know someone posted this before, but I can't find it. What was the solvent that will take off three bond gasket adhesive? It'll be much easier than scrapping.........thanks........steve
XL's: You got love em, make em faster, handle and stop better as they get older: 116 HP & 105 lbs TQ, 88inch Axtell mountain motor.............Steve
9th May 2009
Posts: 1,127 Sportster/Buell Model: XL883C Sportster/Buell Year: 1999 Other Motorcycle Model: Kawasaki Vulcan 500 Other Motorcycle Year: 1996
I don't know what has been said before, but I know that NAPA has a spray on Gasket Remover that does a pretty good job.
Bill in Southern New Mexico - '99 XL883c
I miss Mr. Jimi!
RIP BryanEOD
When I carry a gun, I don’t do so because I’m looking for a fight, but
because I’m looking to be left alone. - Marko Kloos
XLF Road Help [URL]http://xlforum.net/vbportal/forums/showthread.php?t=670716[/URL]
[IMG]http://i742.photobucket.com/albums/xx61/NMBillB/Fur%20Kids/th_KC3.jpg[/IMG]
9th May 2009
Posts: 294 Sportster/Buell Model: XL883 Std. Sportster/Buell Year: 2005 Sportster/Buell Model #2: XR1200 Sportster/Buell Year #2: 2009
LOCTITE 7063 worked great for me.
(do not spray on painted surfaces)
9th May 2009
Posts: 3,192 Sportster/Buell Model: Buell S1 Sportster/Buell Year: 1997 Sportster/Buell Model #2: Buell S2T Sportster/Buell Year #2: 1996 Other Motorcycle Model: Moto Guzzi California Other Motorcycle Year: 2003
Napa sells permatex gasket remover. It comes in a blue spray can, I use it all the time.
9th May 2009
Posts: 688 Sportster/Buell Model: 883/1250R Sportster/Buell Year: 2006 Sportster/Buell Model #2: Buell 1125R Sportster/Buell Year #2: 2009
Nail varnish remover if I remember correctly.
10th May 2009
Posts: 866 Sportster/Buell Model: XL Sportster/Buell Year: 89
I was just using acetone (nail polish remover basically) to clean up my aluminum cases when I noticed it was removing the excess case sealer that NRHS uses.
Hope this helps.
Stock............. Isn't that a soup or something?
10th May 2009
Thanks guys, I hate scrapping those last bits, but I'm probably like ya'll, it's got to be perfectly clean before I'll start reassembly............steve
[IMG]  [/IMG]
12th May 2009
Posts: 1,196 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XR-1000 Sportster/Buell Year #2: 1984
reverse cone
Steve,
Are those true reverse cone megaphones on your exhaust or do you have baffles in them?
Jesse
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
12th May 2009
They are true reverse cone meagaphones, custom built exhaust: 2" headpipes with "x" tube crossover leading to the megaphones. VERY LOUD !!!!!
| Thread Tools |
| Display Modes |
