The Sportster and Buell Motorcycle Forum Zipper's Performance
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Sportster Specialty
Biltwell
Marks Moto Gear
NRHS
Old 2nd April 2005
Predator's Avatar
Predator Predator is offline
Senior Bike Builder
Sportster/Buell Model: NRHS 88" Custom
Predator is on a distinguished roadPredator is on a distinguished roadPredator is on a distinguished road
Default Normal oil temp??
I spent today riding my new 2003 sporty. I noticed the oil tank was really hot and the temp gauge said 200 degrees. Is this normal?
Also, the engine backires throught he carb sometimes and the throttle response from idle is really bad. When you get on the gas from idle it just bogs. Any ideas??
Cameron
Old 2nd April 2005
rider1951's Avatar
rider1951 rider1951 is offline
Other Motorcycle Model: Suzuki DL1000
Other Motorcycle Year: 2002
rider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the roughrider1951 is a jewel in the rough
That is about the temp my bike runs at on long rides in 50 to 60 degree temps.
Impact Blue 1200 Custom, Gronk's mod stock exhaust, Ram-Flo 400, 45 slow, N65 needle, 175 main, HD detachable windshield and rear rack/ back rest, lay-down license plate, Mustang wide vintage, Progressive 13 1/2" 418s and Progressive fork springs w/ Belray oil, Superbrace,
Old 2nd April 2005
Depending on how hot it is outside, it is quite normal. If it does not get to at least 180, the mosture in the oil will not boil out.
Cameron
Well Cameron, I will ASSUME that you bike is all stock. The Jets in the Carb are set very lean for emissions, and can cause a back fire or bogg, so can leaking Intake seals.
without being able to see the bike it is quite hard to give a diagnoses, check the intaka seals, if that is not it, take it over to the dealer.
Old 2nd April 2005
txsporty's Avatar
txsporty txsporty is offline
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
txsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished road
Temps about right!!
May need to rejet!! Check out Stevo thread on Rejeting..
Old 2nd April 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
cantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to beholdcantolina is a splendid one to behold
Cameron
Sounds lean....need more info...get a manual...
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
Old 2nd April 2005
Predator's Avatar
Senior Bike Builder
Thanks for the help. I thought it may have been jetting i'll have to check it although i'm at 6000' so if it's lean from factory it should get better with altitude. I'll look for that thread from Stevo.
Jeffy,
One thing I like about harleys is that you can do the work yourself. I'm not a dealer man. Too much fun to be had wrenchin.
Old 2nd April 2005
Predator's Avatar
Senior Bike Builder
I just read the Stevo rejetting bible. On Ya Stevo!!!!
I've got a dyno so i'll do some testing.
Stevo, 12.7 AFR max power??? Are these engines alot different to cages in that respect. I always find around 13.1 is max power on those four wheeled thingys.
BTW. I'm definately not doubting you. Just want to learn.
Cheers
Old 2nd April 2005
Jimbo999's Avatar
Jimbo999 Jimbo999 is offline
Riding with Angels
Sportster/Buell Model: Sportster XLH 883
Sportster/Buell Year: 1988
Jimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the rough
Where the heck do you live.....Tibet ???????
Try n' catch the wind
Stage 1
Taxes Paid
Blue Loctite is your Friend
Old 2nd April 2005
Predator's Avatar
Senior Bike Builder
I live in Mexico City
Old 3rd April 2005
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
DPT living in mexico you might want to add a oil cooler, a good one will drop your temp. 20 degrees. I live down on the coast of texas and the summers get pretty hot here! Also when you get your bike broken-in you could run synthetic oil that too would lower your temp. as much as 20 degrees too!
Similar Threads
HurricaneFlow Air Cleaners aswracing NRHS - High Performance 85 10th September 2005 18:25
04 oil temp gauge test TechRep Sportster Motorcycle Accessories 5 1st May 2005 03:22
