The Sportster and Buell Motorcycle Forum Licks Visormatic
Biltwell
Speedway Instruments
Marks Moto Gear
Old 31st May 2009
jleable's Avatar
jleable jleable is offline
jleable is an unknown quantity at this point
Default Nightster w/ adjustable highway pegs
I just put a pair of these on my Nightster and wanted to share the pics because when I was doing research on them before I bought them I couldn't find much. I got them from JPcycles for $100 bucks and the install was really simple. Harley sells the same kit for $200plus. They only come in chrome so I sandblasted them and primed then painted them medium gloss black. They turned out pretty sweet and its a way cheaper option than forward controls.
2009 Nightster Silver/Black; VH chrome short shots, VH Fuel Pack, NRHS HurricaneFlow
Old 31st May 2009
Darkling's Avatar
Darkling Darkling is offline
Darkling is an unknown quantity at this point
Hi there. What's the clearance between the gusset plate and your engine casing? I have a similar set up, but bolted the gusset plates so that they point downwards, away from the engine. I tried it the other way, but there was no clearance. I have short legs, well actually, I am just short, so I had to modify the bolt holes to move the pegs closer to me, but it works great.
Old 31st May 2009
jleable's Avatar
there is enough clearance to mount them up for sure. I think there is an eighth of an inch on each side
Old 31st May 2009
Chasmo Chasmo is offline
Sportster/Buell Model: 883/1200 Bobster
Sportster/Buell Year: 1986
Sportster/Buell Model #2: XLH1200N
Chasmo has disabled reputation
Default Extended foot pegs
I bought the same set up for my new nightster on ebay. when i installed the right side, the frame bracket contacted the engine cam cover case HARD. The whole frame vibrated so bad i would not take out of the drive way. I removed it and ground the top and still could move the motor by hand to cause contact. I enlongated the mounting holes and lowered the whole bracket about 1/4" and all is fine, 'specially with Iso pegs. I learned that there is A LOT of motor movement with rubber mounts. My 86 doesnt have that problem, but i cant see anything in the mirror either.
Old 1st June 2009
jleable's Avatar
Now i'm kind of worried. I went out in the garage and rechecked the clearance. I have an 1/8 inch on each side for sure. I took it for a test run around the block and didn't have any problems. The real test will come tomorrow when I drive to work. Anyone else had problems with this setup?
Old 1st June 2009
wookster wookster is offline
Sportster/Buell Model: 07 roadster
wookster is an unknown quantity at this point
I have some on my bike I got cheap for an 03, then made my own brackets.I had someone watch the clearance from the side wile I sat still and torqued the engine with the clutch and front brake. If you do this be careful.
