The Sportster and Buell Motorcycle Forum CV Performance
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
Figure Machine
Lickscycles
CV Performance
Figure Machine
Licks Cycles
Old 14th June 2009
xraytoken xraytoken is offline
Sportster/Buell Model #2: 883C
Sportster/Buell Year #2: 2000
xraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the roughxraytoken is a jewel in the rough
Default What happened here?
Road my 05 1200 Roadster to a small event about 320 miles from home. About a week and a half prior to the trip I installed a new battery, since the old(original) battery didn't seem to hold a charge. Road up, no problem, checked into my room, took a shower, layed down for about an hour, then started the bike and rode over to the event. Hung out for about two hours, fired up the bike and rode back to the motel with the brights on, a distance of about six miles. Got up the next morning, started the bike, stopped at Mickey Dees, started up, stopped at Dunkin Donuts, and when I went to start the bike, dead as a doornail. No lights, nothin'. Checked the kill switch, battery connections, everythings OK. Called a coupla guys from the event, they came over and we tried to jump it, it just barely turned over. Another guy offered to start it with his car battery, NG. So I make arrangements with another guy from the event to load the bike onto his trailer and he'll give me and the bike a lift about halfway home and there's an HD dealer just down the road from him. He shows up about six hours later(I had gone back to the motel) and we're lining up the bike to load onto the trailer and I decide just to try and start it. It fires up like there was never anything wrong! I put it on the trailer anyway. We unload when we get to our destination, I try starting it again and it fires right up! I stay over that night and the next morning it starts right up and I rode it home. I can't figure out why it wouldn't start and wouldn't accept a jump, but later on it started. Any ideas?
Ol' Headbanger of the Donkey Punchers MC
Old 14th June 2009
jharback's Avatar
jharback jharback is online now
Other Motorcycle Year: 1998
Sure sounds like a cable to me.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
Old 15th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Erratic Hard/No-Start
+1 on the cables. It's a connection somewhere, and it won't heal itself. It might work for a while, but then it will bite you if you don't fix it.
Old 15th June 2009
KWJams's Avatar
KWJams KWJams is offline
Sportster/Buell Model: XL 883r
Other Motorcycle Model: HD Road Glide
KWJams has disabled reputation
Check the battery posts. Some batteries have a steel insert in the lead post that the bolt threads into. The bolt could be tight in the insert but the cable could be making an intermittent contact. Put a washer on the bolt so it doesn't bottom out in the steel insert.
Motorcycle Basics --- Suck --- Squeeze --- Bang --- Blow!
Old 15th June 2009
ReddTigger's Avatar
ReddTigger ReddTigger is online now
Red Beard Cycles
Other Motorcycle Year: ALL
ReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud of
Cables to me as well..
however, Take all of the fuses, and relays out of the fuse box, clean each contact with some emery cloth and put di-electric grease on each one. making sure each has good contact.. (this tip from the Master Mech at my dealership) Those rubbermounts are a pain and they CAN drain a battery just from sitting..
I AM THE REAL BAT-MAN!
You Can't Fix
STUPID !
Originator of the "NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,
Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
Old 15th June 2009
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nice
clean the electrical connections
I would use ox-out or another brand of electrical grease that prevents corrosion. lowes or home depot should have it. you use it for aluminum to copper connections.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 15th June 2009
FoxsterUK's Avatar
..or just use Vaseline, does a perfect job, costs next to nothing and you can find some easily
Fox
I had an '05 1200R.
Old 15th June 2009
xHDrider's Avatar
the ox-out is more conductive then a lot of products. the NEC requires it in residential and commercial wiring. I even use it on autos, trailers and bikes.
even though its required on dissimilar conductors its a good product to be used even on high wattage lighting conductors. when resistance goes up from bad connection, current goes up too.
Old 16th June 2009
Well, I cleaned all the connections and used the grease, we'll see what happens. Nothing looked exceptionally corroded or oxidized. I do want to meet the guy who designed the location of the negative lug on the engine case. I want to beat him like a rented mule.
Old 16th June 2009
wilbur's Avatar
wilbur wilbur is offline
The crazy one...
Sportster/Buell Model: rigid 88" highly modified
Sportster/Buell Year: '03
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
You can use my bat!!!!
It is now "later" than it has ever been!
