Sportster Specialty
Speedway Instruments
Licks Cycles
NRHS Performance Long 2
Old 16th June 2009
matte black's Avatar
matte black matte black is offline
matte black is an unknown quantity at this point
Default how tachy
i just got my 75 xlh on the road and tachis not working and i think the cable is good. is it common for the drive gear to break or malfuntion can it be repaired or would it need to be replaced. my harley service manual is missing info on this topic. any direction would be great.
Old 16th June 2009
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
If it`s like mine the tach drive just unscrews, you should be able to remove the cable and look to see if it spins with the motor running.
Yes: cable or tach bad
No : tach drive issue
Old 16th June 2009
Undo cable at both ends. Remove cable from sheath noting which end is top/bottom. Spray any solvent thru sheath. Clean cable with any solvent then grease it. Put it back together, re-install.
Somewhere in this process you will discover if the cable is good or bad. Do all this even if the cable tests good as in the previous post.
Old 17th June 2009
Thanks for the direction i discovered that it is the tach is broken the cable and drive is good, which is better an electronic or mechanical tach? Are there any features i should look for with the new one.
Old 18th June 2009
I replaced my original 1980 mechanical tach with an NOS 1981 electrical version from eBay. Looks the same but no cable. Really nice to have that cable gone.
Old 18th June 2009
A few less cables is not the worst thing. thanks again for your help
Old 18th June 2009
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nicexHDrider is just really nice
I see the older tach at a good price on ebay quite often. I'd keep it stock.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
