Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Frame Mount EVO Sportster Talk (1986-2003 models)
Progressive Suspension
Biltwell
Biltwell
Biltwell
Old 24th April 2007
Swankster's Avatar
Swankster Swankster is offline
Master Bike Builder
Sportster/Buell Model: Nill
Swankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the rough
Default Confused! What happened?
OK, I went on a long ride and was returning from Monterey to the valley, a distance of around 150 miles this past weekend.
Bike ran perfectly and I decided (like we all have at one time) to test its limit or top speed after interchanging from one highway to another with little traffic. Funny, had never really done that before.
Well I buried the speedo at 120 mph pretty easily and quickly with it still pulling really hard.
A good thing yes!
Anyways continued at a really brisk pace because it began to rain on me, and my velocity stack does not appreciate precipitation very well.
Iv'e been dealing with a little more blow by than usual but I just wipe her up when there's the need (even while riding). Blow by comes harder of course with higher RPM's.
As you may recall I have the Wimmer external breathers.
Cruisin along at a good clip with more traffic ahead I downshifted to 4th to get a charge to pass a long line of cars glued to the fast lane. When I hit 5th during a speed shift, it wasn't there, instead a fake neutral and revvvvved her to its limit (of course only for a split second). Big bellow of blue smoke from the exhaust at this time. Off the throttle and put her in 5th and continued on....
For a moment anyways, until I glanced down to the carb side and holy shit what do I see, what looked like a cup or more of motor oil sprawled on the side of the tank, upper rear head/rocker area, carb, my right upper inner leg and my inner arm sleeve.
Pressure was still up there around 20-22 lbs. although dropped a few pounds but stayed constant. A real freakin mess for sure but I was only about 15 miles from home.
Continued into town and stopped by my indy although it was now past closing time. No one there. Drove home and pressure stayed the same.
Got home and litterally poured fairly hot water with Simple Green around the affected area after the motor cooled a little.
Cleaned up the area pretty good and no appeareant leaks.
Next day nothing and cleaned her up even better. Started the bike warmed it and went for a short ride, nothing again except oil level was down around a half quart. It was down slightly too when I left for the coast.
Some background info...
When I first got to my brothers place in Santa Cruz I wiped up the usual blow by and then I got this grand (or stupid) idea I don't know? to assist the small filter elements inside the breathers to better collect the oil. What I did was cut some of that blue absorbant shop cloth/paper and wrap it around the filter elements. I first tested the paper to make sure you could breath through it. Yes I could and I only circled the round filter once with the paper.
Of course my thinking was that it would assist in soaking up some blow by; by eliminating it from escaping through the slots on the breathers. It seemed to work until the incident.
I'm going to head off to the indy shortly and have them check it out but I forgot to mention that when I cleaned up the area, I removed the paper that was still intact yet saturated as you can imagine. what I did see however was some orange powder coat material peeled away from the inner slots or vents of the breather. Nothing externally but evidently from the inner sides of the slots or breather vents.
With that being said, I can assure you that the vents or slots were not plugged, blocked or restricted by over spray of powder coat material. The coating however in the vents of the breather were not spot-on, yet did not concern me because you really did not see into that area.
I do wonder though if the blue cloth paper material, once saturated in oil may have compromised or severally restricted the intent of the breathers????
Of course with the slight blistering or peeling of the orange powder coat, I wonder if a bunch of oil puddled in the breather reservoir due to its restriction causing the oil to get quite Hot (seems unlikely though) and then finally having to erupt all at once and ending up all over me.???
For a clearer illustration I'm enclosing this pic.
What say you; experts out there?
Swankster
"Stop Global Whining"
"Life, Liberty and the Pursuit of Anyone Who Threatens It"
"A Dead Enemy Is A Peaceful Enemy - Blessed Be The Peacemakers"
Still BIKELESS & hating Life!
Old 24th April 2007
Jimbo999's Avatar
Jimbo999 Jimbo999 is offline
Riding with Angels
Sportster/Buell Model: Sportster XLH 883
Sportster/Buell Year: 1988
Jimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the rough
I'm no expert but I'd say the missed shift caused an over pressure the breather
couldn't handle and it puked out the filters...Obvious observation I guess.
Solution ???? Don't miss your shifts. It's prob' the only way to avoid
the mess afterwards.
Just saying, Huh?
Try n' catch the wind
Stage 1
Taxes Paid
Blue Loctite is your Friend
Old 24th April 2007
chrishajer's Avatar
High RPM causes more oil to come out the breathers. I think it's as simple as that.
--Chris
Old 25th April 2007
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
I agree with Chris, adding to this the extra cloth that you installed would restrict the head breathers especially once they get oil soaked, I would remove the extra cloth. Those filters look great, I almost got some but thought they would be high maintenance.
--Chris
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Old 25th April 2007
Joe Dirt's Avatar
Joe Dirt Joe Dirt is offline
Joe Dirt has disabled reputation
--Chris
I think that is all it is. You just ran the snot out of it.
Which reminds me, I still need to do an external breather on mine. Anything more than a brief ton-up run and I'll get oil in the air cleaner.
Old 25th April 2007
Little_Dave's Avatar
Little_Dave Little_Dave is offline
Sportster/Buell Model: 2003 heritage model
Other Motorcycle Model: MZ ETZ 250 cc
Other Motorcycle Year: 1986
Little_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura about
Can you post a pic of the whole bike, it looks pretty interesting from the info on your post!
Old 25th April 2007
Swankster's Avatar
Master Bike Builder
--Chris
Well Chris I spoke to my indy and he checked it out and simply concluded like you and others, that my need for speed caused the condition.
I knew I had some typical blow by from my usual antics but Jeeeeeez! I just couldn't believe the amount.
You know when I think about it, I probably was so fixated on the road ahead at those speeds, rather than looking about I didn't even notice it until that momwent when I did look down and discover the mess.
A pic for the UK guy....
Swankster
Old 26th April 2007
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud ofBruce has much to be proud of
Swansker, Great looking bike, the Chevy in the background does'nt look bad either. Show us a better picture of the car.
Ride safe!
Member of "The Cell #2"
Old 26th April 2007
Swankster's Avatar
Master Bike Builder
The car, one bad ass 1956 Chevy Hot Rod!!! Belongs to my indy.
Swankster
Old 26th April 2007
Paulie420's Avatar
Paulie420 Paulie420 is offline
~~RIP Johnny G~~
Paulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the roughPaulie420 is a jewel in the rough
You'll have less blow by if you use a normal A/C.
Especially when riding hard, I wouldn't suggest a velocity stcack.
Your bike looks so f-in badass though, nice!!! I assume thats part of the reason you run a stack - it looks GREAT with your setup.
Good luck man...
PAULIE
2005 Sportster 1200 Custom
Vance & Hines Sideshots, Screamin Eagle A/C, Detachable Sissy Bar, LayDown Brake Light, Smoked Lenses, SaddleBags, And an Attitude to Boot
